Thread: Steering issues... hub assembly?
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: Steering issues... hub assembly?
    PA
    Quote Originally Posted by GreenNirvana101 View Post
    Alright, so I installed the sway bar, and the sound is still there....
    I'm thinking it might be my struts, springs, or lower control arm bushings? any of these make a creeking noise when turning hard?
    I would consider looking at the strut bushings. They can make a creaking/grinding noise when turning if they are bad.
    2001 GSE
  2. #22 Re: Steering issues... hub assembly?
    GT Level Member GreenNirvana101's Avatar
    Feb 2008
    Wisco
    How do I check them? Just look for any rips/wear, or is there a better way?
    Former Camaro muscle and DSM turbo owner - now moving into the GTP Supercharged world!
    1997 GTP - STOCK.... for now
  3. #23 Re: Steering issues... hub assembly?
    PA
    Don't know of a good way to check them without taking them out. Maybe someone has a better way. But if I remember correctly, you are running a 97 GTP with 140k+ miles? If they are stock struts, I would bet they are stock strut bearings. If they are stock strut bearings, I would bet they are bad.
    2001 GSE
  4. #24 Re: Steering issues... hub assembly?
    Saraland Alabama
    Quote Originally Posted by Zef_66 View Post
    agreed, only way I know also is pull them (they are really just a bearing) get the quick struts and not have to worry, spring strut and mount all together
  5. #25 Re: Steering issues... hub assembly?
    PA
    Quote Originally Posted by archemedes View Post
    The only thing that I don't like about the quick strut is how soft they are. If you don't mind suffering a little handling with your car, then by all means put on the quick struts. But I installed the GMPP handling kit so I would have better handling. I am not going to take a step back and use soft springs in the quick struts. Some might, but I won't.
    So just my $.02.
    2001 GSE
  6. #26 Re: Steering issues... hub assembly?
    Feb 2008
    Wisco
    Alright, I hate to keep bringing this thread back, but the problem is still not fixed. Yesterday Jacob (URLOSN) took a look at it for me (thanks again!), and this is his theory... I'm just curious if anyone else had experienced this.
    He thinks it might be a bad lower motor mount... which puts an entirely new perspective on this problem, but it makes the most sense. My issue is that my car makes a low creaking noise when only turning right. Further, when I give it about half throttle from a stop, I feel a vibration up to about 20mph.
    Anyone else have any input on this, or have had a bad lower motor mount in the past?
  1. Tire Issues
    By TFBuckeye in forum Tires & Wheels
    Last Post: 04-18-2008, 08:12 PM
  2. engine issues ??
    By sal3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-10-2008, 06:24 PM
  3. Hub Assembly causing thunk?
    By Deezul_AwT in forum Tires & Wheels
    Last Post: 03-28-2008, 07:36 PM
  4. Known issues with 98 GTP's?
    By hunter_alexander in forum General Tech Discussion
    Last Post: 03-06-2008, 07:45 PM
