Thread: Trying new plugs - Brisk
Page 1 of 3 123 LastLast
Results 1 to 20 of 53
  1. #1 Trying new plugs - Brisk
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    So here's the deal, I'm a plug fanatic. I've wanted to try the Brisk LGS plugs, but was afraid to run them with my mod level. Brisk didn't recommend running them with the list of mods and boost level. A well respected member here told me Brisk has come out with a new LGS plug that has a tighter gap designed for turbo applications. I have these plugs, and am planning on putting them in this weekend. Hopefully the well respected member will jump in this thread with his findings, once he gets his set installed.
    Currently I'm running AL 104's @.050. Out of all of the plugs I've tried, my car idles, excellerates best with the NGK TR6IX plugs. Obviously SOTP differences are quite subjective and not completely helpful.
    If I do any real testing, is there anything anyone wants to know about that I can somehow document?
    One thing to note. Upon visual inspection there is inconsistancy in the silver center electrode. I would have thought a plug designed like it is would need tighter tolerances, but that is just speculation at this point.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  2. #2 Re: Trying new plugs - Brisk
    GT Level Member TurboKent's Avatar
    Woodward, OK
    hmmm.... will follow this one, curious myself on how the turbo design ones compare. Currently i'm running the AR103's
  3. #3 Re: Trying new plugs - Brisk
    Saraland Alabama
    this should be interesting
  4. #4 Re: Trying new plugs - Brisk
    St. Louis Mo.
    You know I am near by to help ya Lee, just say the word and I will jet on over to help ya
    James Shafer
    St. Louis MO
  5. #5 Re: Trying new plugs - Brisk
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    Quote Originally Posted by GeddyLee View Post
    Same here, ya know I am down for anything.
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  6. #6 Re: Trying new plugs - Brisk
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    Watching this thread for the same reason as Kent.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  7. #7 Re: Trying new plugs - Brisk
    Oklahoma
    Watch out for that power build up, its murder on transmissions
  8. #8 Re: Trying new plugs - Brisk
    St Louis MO
    Crap, I forgot about your and Daves cars giving up the ghost right after the Brisk install. Well if bad stuff is going to happen it will happen to me.
    TurboKent - I ran the AR 103's for about 10K miles right after my cam install. They started to give me idle issues right around 9K. 5-10k, but seems exceptable for plugs that don't cost an arm and a leg.
    James and Steven. Hint hint for another STL mod day. I could use a co-pilot wathcing the HPTuners while doing some scanning. Not sure how to quantify results, like mpg and smoothness of idle, or general SOTP differences. When I went from the AR 103 that had expired to a new set anyone would have felt the difference. However, that was going from bad plugs to brand new. That type of comparison should be discounted imo.
    I guess pictures would be helpful. Any local guys with a good camera capable of taking clear close-ups? I really would like to show the six plugs and their condition before starting this process.
    2010 Camaro SS LS3
  9. #9 Re: Trying new plugs - Brisk
    Oklahoma
    I remember starting a thread a long time ago here trying to get some input on how to standardize and quantify plug effectiveness. Guess it might have been helpful if we had come up with something. But I recall the thread falling off because trying to decide how to deal with all the variables being too much.
    That said, I am into plugs probably as much as you are and I would definitely be willing to collaborate with coming up with some sort of test methodology. As far as I know there is no ASTM or ISO standardized testing for plugs so we would be pioneering new ground in a way if we did. So if you want to work on it, I am more than willing. I personally think it would be a good collaboration actually.
    With that a few things that come to mind:
    1. Ease of spark - Does one spark plug fire easier, over come the gap better than another, minimum voltage needed to spark (not sure how to test for this)
    2. What are the internal resistances of the plugs - Measure with a multi-meter
    3. What kind of configuration is the plug - Surface gap, Sidegapped, Conventional, etc.
    4. Idle improvements - Again, not sure how to measure this, I have some ideas though.
    5. Fuel Economy - Easy enough to measure, just have to standardize the way the tank is filled up. I wrote an article on this once and the ways you can measure fuel economy, so I got that covered.
    6. Acceleration - Several variables here, but if we could come up with a few testing standards, it would at least give a general overview.
    7. Quality - How well is the plug made.
    8. Materials - What is the plug made of
    If you are serious and want to try it, I would be more than willing to work on it and see if we can come up with something. We could even try and build a test stand (basically a power source, coil and plug) and fire plugs that way. The fact is that there will always be unaccounted for variables no matter what we come up with. However, if we just take a stand and start somewhere, we can come up with something and then improve it as we collect data.
  10. #10 Re: Trying new plugs - Brisk
    St Louis MO
    Definitely potential here.
    1. Easy of spark - I'm with you here, not sure how to test this especially in a DD engine.
    2. Resistance - I have a Fluke 77 and an oscilloscope.
    3. configuration - easy enough, although I'm not sure how to classify the LGS configuration.
    4. Idle - On a car with an XP cam, that would be tough, Although a before and after scan would be all that I could come up with.
    5. Fuel Economy - I drive the same 60 miles everyday so no big deal. Although perhaps not accurate, wouldn't just going by the DIC at least be consistant? Mine seems to be as long as I intentenionally maintain a give MPH.
    6. Accelleration - I'm not sure on this one. A dyno would be a good way, but not in my budget nor something I want to put my car through.
    7. Quality - somewhat subjective, but none the less a needed item.
    8. Materials. usually we only know information about the center electrode. In plugs like the Autolites, we know the "core" is copper, however we don't know what the coating exposed to the spark is made of. Brisk Silver racing plugs are solid silver...Trannyman, have any pictures handy? Some of this info will only be what is published by the maker. As this is the case we will have to be careful not to call things like copper core, copper...ect.
    I can get some resistance reading, on AL 605, 104, NGK TR6IX, Nology Silver Racing, and Brisk LGS plugs pretty quick.
    One thing to note is that since our ignition module has a current limiting circuit, resistance or lack of, may actually have little to no effect. Still know the resistance would be interesting, although impedance moreso.
    2010 Camaro SS LS3
  11. #11 Re: Trying new plugs - Brisk
    Apr 2008
    I am new to this forum and am trying to find out if anyone else is or has had my problem. My 2000 GT is hesitating while idling. I replaced all the Coil Packs which did not help. Fuel Filter was replaced about a year ago(before this problem). Anyway, does anyone have suggestions as to what might be going on. Could it be the plugs and wires. If so, is it expensive to get them replaced?
    Thank you!
  12. #12 Re: Trying new plugs - Brisk
    St Louis MO
    Quote Originally Posted by elriqo28 View Post
    Thank you!
    plug wires are around $35 from rockauto. Could be a clogged injector(s) dirty or not funtioning properly MAF or IAC, bad plug(s) (carbon tracking, worn out, cracked insulator..etc)
    Your post should probably go in it's own thread for more help since this thread is more about spark plug comparisions. Not being mean, just that more exposure for your issue will likely render more opinions.
    Welcome to the GPF forum. btw I think someone else started a thread about poor idling not long ago. Although I don't know how good the search feature is here, it may be worth a try as well.
    2010 Camaro SS LS3
  13. #13 Re: Trying new plugs - Brisk
    St Louis MO
    An update. Looking at the LGS center electrode again, I guess slight variations may not be detrimental. What I found even more interesting is that the the 4 ground electrode do not seem to be the same distance away from the center electrode. There is a possibility that the spark may only jump to the longest ground electorde. Once the current longest ground electrode wears down it may start sparking to the next longest electrode (shortest current gap). Who knows but I think I'm going to install these on Sunday.
    I also made note in an earlier post that on the Nology Silver Racing plug box it says "by Brisk". The nology labelled plugs are cheaper than the Brisk.
    2010 Camaro SS LS3
  14. #14 Re: Trying new plugs - Brisk
    St Louis MO
    Put the new plugs in today. Although I can't tell any difference yet, I'll need a couple of days driving the 60 miles back and forth to work to get a real feel for any changes.
    2010 Camaro SS LS3
  15. #15 Re: Trying new plugs - Brisk
    Oklahoma
    If the LGS plugs you have are like the ones I bought from you, then it is a surface gap design. One of the advantages of that design is supposedly easier firing of the plug.
    With regards to fuel economy, do you have any certified truck scales along your route? If so, that is going to be among the most accurate way to test fuel economy. In fact I believe there is an ASTM standardized test for measuring fuel economy that way. While the D.I.C is decently accurate if you drive all highway or all city but through any combination in there and it begins to show sizable errors. So if at all possible, using truck scales would be the most accurate way as that removes any inaccuracies in tank fill, temperature and so on.
    Acceleration will be a tough one for sure and its sole purpose would be to serve as a cumulative representation of the plug. In other words it would be a big picture view of plug performance not measuring anything specific.
    Materials would just be a general thing so that we can distinguish the construction of plugs of similar configuration.
    Even with the current limiting factor of the ignition module, I do not think that it will be an issue. As voltage goes up, current comes down. So it is unlikely that will come into play, and if it does then we will have one heck of an ignition system on our hands. Though I would like to know what current level it is limited at. And I agree that impedance may be a better number to note since we have the coils in play, but to accurately calculate that, we will need to know the resistance of the plugs wires, etc.
    Im wondering Lee, if to get this off the ground, if it would not be better to build a test stand? Sort of like a litmus test. If the plug shows favorable results with the test stand then install them and proceed with real world testing?
    I wonder if we could power a ignition module and connect a coil pack up and a plug wire and plug and be good to go. All we would need to do then is just provide the interrupt that the vanes on the harmonic balancer does to the cps to fire the ignition.
    If nothing else, we could develop our test procedures that way, no?
  16. #16 Re: Trying new plugs - Brisk
    St Louis MO
    Zooomer was the one that mentioned the current limiting factor and how pointless it was to buy lowered resistance plug wires for performance benefits. So I can't really comment on that at all, I'm afraid.
    I'm sorry, but I would have to go a long way to find truck scales.
    I agree a test system would be ideal, however time consuming and potentially expensive for what it would be used for. Although very cool.
    Yes the plugs are the same as yours only with a tighter gap for higher boost applications.
    I seriously hope the person that told me about these will step in with some thoughts.
    2010 Camaro SS LS3
  17. #17 Re: Trying new plugs - Brisk
    Oklahoma
    Cool, I will look into the test stand set up. It would certainly get lots of use from me, and I would probably make a run a drying up my mod money testing plugs, LOL.
  18. #18 Re: Trying new plugs - Brisk
    St Louis MO
    sounds good
    2010 Camaro SS LS3
  19. #19 Re: Trying new plugs - Brisk
    Feb 2008
    I'm interested to see how this all turns out, as well.
  20. #20 Re: Trying new plugs - Brisk
    Hoffman/Schaumburg, IL
    for the test stand, we had something at my school that simulated the coils firin to test plugs..... But I dont see why you would need the ICM, all you need is to apply 12V to the primary windings, and disconnect quickly, any time it is powered after saturation, it just makes heat, so you could almost just tap the power to the coil repeatedly and I would think that It would fire every time you tap it(well right after )
  1. Plugs???
    By crashman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2008, 10:00 PM
  2. Brisk LGS Plugs are in!
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2008, 08:20 AM
  3. BRISK plugs came in
    By IndeedSS in forum Off Topic Discussion
    Last Post: 01-31-2008, 11:54 AM
