Thread: P1652
Results 1 to 5 of 5
  1. #1 P1652
    Hobart
    Hey all how's it goin?
    First of all:
    1997 Pontiac Grand Prix GTP
    135,000 miles
    Problem:
    I am throwin a P1652 code and wondering if anyone has experience fixing this problem?
    My Diagnosis:
    I have come to the conclusion that it is a problem with the high speed radiator fan. That would be fan 2
    Tried:
    1) I disconnected the PCM, and checked voltage between engine ground and PCM harness connector fan 2 relay driver circuit......what?? lol, and I got voltage between 9-16V
    2) Checked current through engine ground and fan 2 relay driver circuit and got nothing.
    3) Disconnected high speed fan relay and checked voltage between engine ground and fan 2 relay driver circuit....apprx. 12V
    Suggested Solution:
    Locate and repair short to voltage in fan 2 relay driver circuit.....Ok now i'm lost (NOTE: there is many different possible solutions depending on what readings you get, this is just my specific diagnosis PLUS: idk if I did it right)
    So................any help would be great, thanks in advance!
  2. #2 Re: P1652
    Wichita
    check the sensors
  3. #3 Re: P1652
    Hobart
    what sensors?
  4. #4 Re: P1652
    Wichita
    Check where the wiring harness plugs into the fans
  5. #5 Re: P1652
    Hobart
    so unplug the sensor, which I assume is a temp sensor? And the fans should start up when the car goes on? If i do that they should automatically run on high?
