Thread: Headlight alignment
Results 1 to 7 of 7
Threaded View
  1. #7 Re: Headlight alignment
    Denver Colorado
    Quote Originally Posted by coreygnar View Post
    so i noticed the other day that my left headlight is way unaligned. i decided to try adjusting it. when i started to turn the tork bolt or whatever its calld, it strips badly. i dont know what to do know, is there any thing else i can use?
    Well, you shouldn't have done that without the correct tool. They make them out of brass too so they strip real easy if you try to use plyers or something. If you stripped it out, you are in trouble dude, sorry. The manufacturers do that to keep people away from adjusting headlights that don't know what their doing and end up blinding everyone on the road with low beams. Do not adjust your headlights yourself unless you at least try to learn to do it properly. Torx socket tools are used much more on imports. Here is an example of the proper tools: http://www.google.com/products/catal...ed=0CCkQ8wIwAA#
  1. Alignment kits?
    By Amb4 in forum Brakes/Suspension/Chassis
    Last Post: 04-22-2010, 04:13 PM
  2. Wheel alignment
    By kissmyss in forum General Tech Discussion
    Last Post: 04-19-2010, 12:13 PM
  3. alignment specs.
    By stlmo_gtp in forum Brakes/Suspension/Chassis
    Last Post: 07-21-2009, 02:40 PM
  4. '01 alignment ?'s
    By riceburner in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2009, 04:14 PM
  5. headlight patter alignment.
    By riceburner in forum Visual/Body Modifications
    Last Post: 09-04-2008, 11:16 AM
