Thread: 71 grand prix with key stuck in iginition
Results 1 to 4 of 4
jharper 71 grand prix with key stuck... 04-28-2011, 06:33 AM
matt5112 Re: 71 grand prix with key... 04-28-2011, 12:02 PM
Scottydoggs Re: 71 grand prix with key... 04-28-2011, 12:10 PM
jmt455 Re: 71 grand prix with key... 04-29-2011, 10:03 AM
  1. #1 71 grand prix with key stuck in iginition
    Apr 2011
    castle rock, co
    Hello,
    I just bought a 1971 Grand Prix SJ. The key is stuck in the ignition in the run spot. Will not go into the lock position. I replaced the ignition cylinder with a new one, but still have the same problem. Could it be the neutral safety switch, or something else. Thanks
  2. #2 Re: 71 grand prix with key stuck in iginition
    Moved.
  3. #3 Re: 71 grand prix with key stuck in iginition
    this is a long shot but im thinking the old gm cars with a floor shifter, the back part of the steering column between the key and dash moved when you shift it on the floor, try to turn the that part of the column. im pretty sure theres a linkage bar thats inside the engine bay by the fire wall, that goes from the outside of the column to the trans, it may be binding, seized or broken.
  4. #4 Re: 71 grand prix with key stuck in iginition
    SE Level Member jmt455's Avatar
    SE Michigan
    scottydogs is correct about the linkage; it is controlled by a "back-lock" linkage that is driven by the shifter.
    I've got the 1969 Factory Service Manual pages for the back-lock linkage adjustment procedure. I believe the adjustment procedure is the same through 1973 (maybe all the way to 1977 on GP) I tried to attach the scans but the files are too large. If you PM me your email, I will send the scanned pages to you.
    Make sure the bushing at the column-to-shifter rod linkage is present and in good condition. It's a cheap little part that causes all kinds of aggravation when it is worn or missing.
    83 Bonneville wagon
    08 G8 Base
  1. Finding Grand Prix parts or Grand Prix's in Junkyards near you!
  2. Will a 04 grand prix 3800 engine fit into a 01 grand prix
    By jordan61488 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-24-2010, 01:01 AM
  3. key stuck in ignition 2002 grand prix
    By bidiheston in forum General Tech Discussion
    Last Post: 01-24-2010, 05:39 PM
  4. 98 grand prix se key stuck in ignition
    By Squishy in forum General Tech Discussion
    Last Post: 11-25-2009, 01:45 AM
  5. 2008 grand prix key stuck in ignition
    By goldcoinkid in forum Introductions/Noob Questions
    Last Post: 08-31-2009, 05:11 PM
