Thread: A list of sensors and how they work?
Results 1 to 11 of 11
  1. #1 Re: A list of sensors and how they work?
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    I kind of tried searching the web, but I am not very good at it and didn't find what I want. The reason I said GM tech is because they have access to all of the GM info.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  2. #2 Re: A list of sensors and how they work?
    Hoffman/Schaumburg, IL
    I think if we all collaborate together we can make said list, I'll start:
    Cam Sensor- Hall effect? -used for injector timing
    Crank sensor- Hall effect - two parts, one used for timing, other used for Tach and Traction control
    Intake air Temp-thermistor- Used to help fueling by telling pcm intake air temp
    Mass Air flow - ??? - sends a Frequency that equates to mg/sec of air the engine is ingesting, used for fueling
    Throttle Position Sensor- Potentiometer - used to tell the computer how open the throttle plate is and also the speed it moves can be measured, used for transmission shifting and fueling
    Manifold Absolute Pressure(MAP) - used to run engine during maf failure, also used to aid in fueling and judging engine load
    Coolant Temp. Sensor- Used to tell the temp of the engine through the coolant, assists in fueling(by telling when it is warm enough for closed loop operation)
    There are many more, and if any of above are wrong/ need to be erdited please let me know
  1. Why is CT not in the list of states
    By jacobmh27 in forum Northeast
    Last Post: 04-26-2008, 08:19 AM
  2. Vendors List
    By 19SE92 in forum Forum Bugs/Suggestions
    Last Post: 02-20-2008, 11:36 PM
  3. 2 GP's to add to the list...
    By cigarettebyrns in forum Introductions/Noob Questions
    Last Post: 01-31-2008, 11:47 PM
  4. Free Mod List
    By BLACKEDOUTGTP in forum General Tech Discussion
    Last Post: 01-08-2008, 09:03 PM
