Thread: Replaced hub car still humming
Results 1 to 18 of 18
  1. #1 Replaced hub car still humming
    SE Level Member Cbierniat24's Avatar
    Mi
    I thought my car had a bad hub assembly so I went ahead and swapped it out but turns out it is not my problem. I really only hear the humming/growling noise above 40mph and its coming from the passenger front tire. Any ideas thanks!!
    99gtp 167k miles
  2. #2 Re: Replaced hub car still humming
    Willoughby, Ohio
    probably an axel if its grinding
  3. #3 Re: Replaced hub car still humming
    '02 GTP oneil.GTP's Avatar
    Oct 2008
    Peoria, IL
    been having somewhat same problem tho mines only when turning left from a stop. feels more like a rattle than grinding.
    theres also a slight hum around 45ish. just rotated tires today and overlooked everything to see if something was broke or bent and didnt see anything.
    axle easy to replace or take it to the shop?
  4. #4 Re: Replaced hub car still humming
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    fairly easy if you have any idea what you're doing
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  5. #5 Re: Replaced hub car still humming
    May 2008
    staten island,NY
    could be the axle, i just replaced both front bearings and the drive side axle and no more hum
  6. #6 Re: Replaced hub car still humming
    Mi
    the sound doesn't really change during turns, its noticeable about 30mph, gradually increases. CV Axle or should I change my other hub... getting tires rebalanced tomorrow along with an alignment.... or should I hold off until i replace the 2nd hub?
  7. #7 Re: Replaced hub car still humming
    GT Level Member njbrain's Avatar
    Rhinelander WI
    CV axles only clunk and vibrate. They don't hum.
  8. #8 Re: Replaced hub car still humming
    Oct 2008
    Peoria, IL
    Quote Originally Posted by njbrain View Post
    humming noises are from vibration.. hum a song, tell me if anything vibrates.
  9. #9 Re: Replaced hub car still humming
    May 2008
    staten island,NY
    get an axle from morad for cheap and replace it, hold off on the alignment, if you dont have camber bolts your wasting your money
  10. #10 Re: Replaced hub car still humming
    Charles City, IA
    Quote Originally Posted by QwikGT View Post
    You can also grind the struts.
    SMGPFC Two Nipple General
  11. #11 Re: Replaced hub car still humming
    Mi
    Camber bolts... I do not have any knowledge or experience with these... I found some on pfyc.com is there a better set out there?
    so get the bolts then get the alignment?... if that doesnt fix the humming noise and then I replace the other hub or axles will I need another alignment?
    Just looking for best approach to save $
  12. #12 Re: Replaced hub car still humming
    Greensboro, NC
    I am having a simmilar problem. My left front wheel humms but it stops when I turn the wheel left. The hum goes faster as the speed increases. The previous owner hydroplaned and the car hit a sign on the left front. I had to have the front end aligned. Would it be the axle? The car is a 2000 GTP.
  13. #13 Re: Replaced hub car still humming
    SE Level Member Freimuth's Avatar
    Nov 2009
    Clinton, Ohio
    Could be axle or possible bad tire??
    New to me ---- 1999 Grand Prix GTP 216K miles and counting
    SOLD----1997 Grand Prix SE 3.8 -- 1K miles from the 200k club.
  14. #14 Re: Replaced hub car still humming
    Rhinelander WI
    Quote Originally Posted by oneil.GTP View Post
    It is possible. However, in the three years I have been a Tech I have never seen it. Usually the reason the car still hums after bearing replacement is misdiagnosis of which wheel, or on a rare occasion, both are bad.
  15. #15 Re: Replaced hub car still humming
    Greensboro, NC
    So is the humming comming from the wheel bearing?
  16. #16 Re: Replaced hub car still humming
    Mi
    I took it in to belle tire and they told me both front hubs are bad. Before they looked at it I told em I just wanted to figure out what was wrong before I got an alignment aand I would do the work myself.
    So timikens the way to go? Is there a certain one I should stay away from like the autozone ones? What about the ones on Rockauto.
    Thankss
  17. #17 Re: Replaced hub car still humming
    Greensboro, NC
    How difficult is it to replace a front bearing on a 2000 GTP?
  18. #18 Re: Replaced hub car still humming
    May 2008
    staten island,NY
    i bought these from summit, all metal construction, not like that crappy plastic cover on the ZZP ones, this company is made in the USA and they supply the bearings to timken, i checked them out on google prior to buying them. not bad for 100 each
    Wheel Bearings 513187 - Wheel Bearings Unitized Hub Assemblies - Overview - SummitRacing.com
  1. Loud Humming noise... What is it?
    By brownb66 in forum General Tech Discussion
    Last Post: 05-14-2010, 10:24 AM
  2. humming sound while driving
    By foursixer in forum Brakes/Suspension/Chassis
    Last Post: 02-18-2010, 03:42 PM
  3. Humming Noise During Acceleration
    By Burgundyman in forum Brakes/Suspension/Chassis
    Last Post: 01-02-2010, 10:03 AM
  4. humming sound
    By gearheadamongus in forum Audio, Security & Visual Electronics
    Last Post: 07-03-2009, 06:10 PM
  5. new humming noise??!!??!!
    By Morris 04 GTP in forum Brakes/Suspension/Chassis
    Last Post: 02-14-2009, 09:33 AM
