Thread: high-pitched whistle and bouncing idle
Results 1 to 3 of 3
  1. #1 high-pitched whistle and bouncing idle
    SE Level Member CSteen85's Avatar
    Long Island, NY
    Hi guys,
    Over the weekend, I changed my thermostat, which went well. The car now heats up to temp, which I'm pretty excited about. I even got asked out by the guy at Auto Zone, because he was so impressed I was doing it myself, LOL.
    This morning, I was sitting in my car with the window down waiting for the train and I heard this pretty loud, high-pitched whistling sound. At first, I wasn't sure it wad coming from my car, so - tried shifting out of park, but the sound remained. Then, I turned the car off and sure enough, the sound was gone. I also noticed a bit of a rough idle, bouncing only by about 100-200 RPMs, but it doesn't feel exactly normal.
    Are these two related? Could it be a vac leak or is there something else I should look at?
    Recently, I've cleaned the MAF sensor and replaced a vacuum line going to the Throttle Body. I checked a couple of the lines when - changed the t-stat, and everything seemed okay.
    Thanks!
    1997 Grand Prix SE, 3.8L V6 SFI, 140k, purchased on 3/6/10.
  2. #2 Re: high-pitched whistle and bouncing idle
    Donating Users Ibwrong's Avatar
    Oklahoma City
    sounds like a vac leak.. I'd check all your hoses again. Did you replace the big line going into the TB? make sure its seated right.
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  3. #3 Re: high-pitched whistle and bouncing idle
  1. High pitched noise coming from dash?
    By Gortox454 in forum General Tech Discussion
    Last Post: 08-14-2010, 08:48 AM
  2. High idle at times
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-16-2010, 07:48 AM
  3. 94 GTP gas smell and bouncing idle
    By rw53104 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 02-17-2010, 02:21 PM
  4. High idle?
    By WhiteGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-15-2009, 02:14 AM
  5. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
