Thread: 2000 gtp fuel pump wont run after start up
Results 1 to 8 of 8
  1. #1 2000 gtp fuel pump wont run after start up
    michigan
    I have a 2000 gtp the fuel pump will run to pressurizes the rail when I turn on the ignition then turns off like normal but when I start the car the pump doesn't come back on the fuel pressure drops off the car dies I have replaced the relays did not fix problem had the ignition module tested it tested good tried a new ignition switch still same problem no trouble codes come up if remove the relay and jump terminals so the pump is on continuous the car runs great how can I fix this I have searched this forum and could not find the same problem help
  2. #2 Re: 2000 gtp fuel pump wont run after start up
    Jul 2008
    sumter,south carolina
    buy a new relay?
    02 GTP with mods 05 GP for DD
  3. #3 Re: 2000 gtp fuel pump wont run after start up
    GTX Level Member bronzemist02's Avatar
    Canada
    ^ Relay was replaced. Did you check the wiring? May be a fault somewhere in it that is causing it to die.
    02 GT: Silverstar ultras, nighthawk platinum 2157s, ngk plugs, champion wires, 6k hid fogs, stainless magnaflows, cleaned tips, 2 10" subs. Finally painted.
  4. #4 Re: 2000 gtp fuel pump wont run after start up
    Jul 2008
    my bad... i read too fast. what about fuel pump resistor.
  5. #5 Re: 2000 gtp fuel pump wont run after start up
    michigan
    I have checked the wiring where is the resistor?
  6. #6 Re: 2000 gtp fuel pump wont run after start up
    Jul 2008
    theres a write up on here somewhere... just search for fuel pump resistor.
  7. #7 Re: 2000 gtp fuel pump wont run after start up
    Charles City, IA
    Do this
    SMGPFC Two Nipple General
  8. #8 Re: 2000 gtp fuel pump wont run after start up
    Ohio
    ^ that should fix your problem!
    00 GTP demodded and forsale
  1. Fuel pump / Fuel sender question !
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-01-2010, 11:03 AM
  2. Wont start
    By EmEaston24 in forum General Tech Discussion
    Last Post: 08-27-2009, 09:20 AM
  3. >??? dam still wont start
    By TMOTA503 in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-12-2008, 09:58 PM
