Thread: ZZP O2 sensor any good?
Results 1 to 5 of 5
BDEGhost ZZP O2 sensor any good? 04-25-2010, 04:12 PM
minichopper6hp Re: ZZP O2 sensor any good? 04-25-2010, 04:49 PM
97gtsc Re: ZZP O2 sensor any good? 04-25-2010, 05:40 PM
BDEGhost Re: ZZP O2 sensor any good? 04-25-2010, 07:12 PM
Spartan GL Re: ZZP O2 sensor any good? 04-27-2010, 08:30 AM
  1. #1 ZZP O2 sensor any good?
    Quakertown, PA
    Like the title says, are the O2 sensors that ZZP sells any good? I need to replace my rear one since I am getting P0141 code repeatedly even after I reset it. Sometimes, it will take a day or two for the code to come up after being reset, and sometimes it comes up almost immediately. I am not really a fan of putting in a simulator in place of the sensor.
    '02 - 3.8(K) 153,000 miles, New UIM, New LIM alum. gasket, new lifters, new OEM cat. Runs great ! Owned it since new. (bought it 12 years ago with only 22 miles on the clock)
  2. #2 Re: ZZP O2 sensor any good?
    Banned - Busted For Scamming
    Feb 2009
    That code is for a h02s heater circuit malfunction. You first need to determine if the sensor is at fault or the circuit is at fault. Throwing parts at a vehicle is never a good route to go.
  3. #3 Re: ZZP O2 sensor any good?
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    X2^^
  4. #4 Re: ZZP O2 sensor any good?
    Quakertown, PA
    So, what's the procedure to determine whether the O2 sensor is bad or the circuit is at fault somewhere? Can the sensor be checked with a meter?
    Thanks for any help on this...
  5. #5 Re: ZZP O2 sensor any good?
    Largo, Florida, United States
    Like hell! I throw parts at it all the time!
    I'm throwing an engine at it now! muhahaha
  1. HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
    By chamilton89 in forum Audio, Security & Visual Electronics
    Last Post: 08-06-2012, 09:10 PM
  2. O2 sensor after cat
    By monsterjam5000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2010, 03:03 AM
  3. maf sensor
    By betsgtp in forum General Tech Discussion
    Last Post: 04-21-2009, 02:15 AM
  4. Is it possible to run without an O2 sensor?
    By Andrew_99GTP in forum PCM Tuning
    Last Post: 06-19-2008, 11:45 AM
