Thread: possible?
Results 1 to 8 of 8
  1. #1 Re: possible?
    Banned - Busted For Scamming
    Feb 2009
    You have to disconnect the battery, wait at least 10 min. and then there are 4 10mm nuts on the back of the steering wheel, they hold the air bag in. From there you pull out the air bag and you see the clock spring, take it out and then a nut holding the steering wheel on and then you use a steering wheel puller to take it off. Simple.
  2. #2 Re: possible?
    Jul 2008
    sumter,south carolina
    thanks for this info, last trans me and my friend put in.. steering knuckle came loose, steering wheel made several free turns and set airbag light.. clock spring is culprit. just never knew how to fix it. didnt really bother me too bad to make a thread or search.
    02 GTP with mods 05 GP for DD
