Thread: Wheel alignment
Results 1 to 5 of 5
  1. #1 Wheel alignment
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    Is it necessary to have an alignment done when replacing the front bearings or ball joints. I'm getting the work done at the dealer and would like to know if it's automatically done with this type of work or should I request it.
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
  2. #2 Re: Wheel alignment
    Charles City, IA
    Should not have to. If it pulls after wards then yes. Also **** the deal ship. You can do the bearings in like 1 hr for both. And ball joints are not bad either.
    SMGPFC Two Nipple General
  3. #3 Re: Wheel alignment
    Donating Users Warbeaver's Avatar
    St. Louis
    shops will tell you to do an alingment, but hey, its a shop and what can you expect from them? they will sell you anything
    you don't need an alignment. you arent messing with anything that would affect camber or toe.
  4. #4 Re: Wheel alignment
    Jan 2009
    ny
    It's still under warranty
  5. #5 Re: Wheel alignment
    Charles City, IA
    Quote Originally Posted by kissmyss View Post
    Tell them it pulls also then. Then ask for an alignment.
  1. Ahh alignment issues. what is wrong here?
    By 04CompG in forum Brakes/Suspension/Chassis
    Last Post: 01-17-2010, 12:42 PM
  2. alignment specs.
    By stlmo_gtp in forum Brakes/Suspension/Chassis
    Last Post: 07-21-2009, 02:40 PM
  3. What kind of wheel alignment do I need?
    By 04CompG in forum General Tech Discussion
    Last Post: 03-22-2009, 11:23 PM
  4. '01 alignment ?'s
    By riceburner in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2009, 04:14 PM
  5. Trouble with Alignment after new supsension.
    By John_Shughart in forum Brakes/Suspension/Chassis
    Last Post: 04-08-2008, 06:36 AM
