Thread: Fire Extinguisher mounted.
Results 1 to 20 of 23
  1. #1 Fire Extinguisher mounted.
    Wichita, KS
    Decided to mount my fire extinguisher inside the cabin with me, and in a place thats with in reach in case its needed.
    My original plans were to mount it in the trunk out of the way, but I can see as fate would have it, there is either a fire that takes out the electrical supply, or an electrical short that starts a fire, either way, I would be S.O.L. getting inside the trunk because I have shaved my trunk lock.
    Next best place was under the glove box, and use the existing holes, and screws that are already there.
    I started off measuring, and did a dry install and it will fit, but not all the holes lined up that the bracket had predrilled in it already. So made another hole, the one my finger is covering up:
    Got it mounted using the screws that hold the glove box to the frame of the dash, so its a real strong secure mounting point:
    extinguisher now installed:
    To show that it really doesn't take up all that much room where its at:
    Dog will hunt!
    ~F~
  2. #2 Re: Fire Extinguisher mounted.
    Looks good! ive been trying to figure out where to mount mine. I was thinking trunk as well, but have dismissed it for the same reasons you mentioned. The only thing that keeps me from mounting it where you mounted yours is the inevitabe question of " why do you have a fire extinguisher in here..." since the best response ive come up with is "um... to put out fires..."
  3. #3 Re: Fire Extinguisher mounted.
    not 2 shabby!
  4. #4 Re: Fire Extinguisher mounted.
    Jan 1970
    Maquoketa, Iowa
    GM should have equipped these cars with one from the factory.
    Our luck, they probably would have put it on the passenger side a-pillar! lol
  5. #5 Re: Fire Extinguisher mounted.
    TDCRacing
    Guest
    Quote Originally Posted by FoSHO99 View Post
  6. #6 Re: Fire Extinguisher mounted.
    Moore, Oklahoma
    Looks good Jason! Where did you get that extinguisher at?
    Shawn W. Larsen
  7. #7 Re: Fire Extinguisher mounted.
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    on a related note, farns, have you thought about adding in a cable actuated trunk release like under the back seat or so? i've often contemplated such a thing when discussing shaving trunk locks... i mean, new cars have a short one inside the trunk for safety, so it cant be that hard to put something together, no?
  8. #8 Re: Fire Extinguisher mounted.
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    Very nice Jason. After I saw what happened to WasteU's car I have been really wanting a fire extinguisher in my car. If you don't mind me asking where did you get it at. And is there anything specific one would need to know when purchasing a fire extinguisher? I know they make different ones for different types of fires.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  9. #9 Re: Fire Extinguisher mounted.
    Wichita, KS
    Quote Originally Posted by Iron Indian View Post
    I got it as a present this past year for Christmas from the GF. It was on my list too.
    She bought it locally from a fire safety store that does residential as well as commercial stuff.
    I know its a ABC rated one.
    It was made by, or distributed by:
    Amerex Corporation
    Trussville, AL
    (205)655-3271
    email = sales@amerx-fire.com
    web = Amerex Corporation - About Us
    ~F~
  10. #10 Re: Fire Extinguisher mounted.
    Wichita, KS
    Quote Originally Posted by Toasty View Post
    Possible.
    My car is a '97 and I installed a lock assembly from a 2001 that has the glow in the dark t-handle attached to the lock from inside the trunk. That way if your ever locked in the trunk, this will open it etc. I can get to it through the center fold down in the rear seat, but why climb back there if there is a fire...I want to get to it as quick as I can blink my eye.
    ~F~
  11. #11 Re: Fire Extinguisher mounted.
    SW Chicago Suburbs
    Quote Originally Posted by GR8racingfool View Post
    Possible.
    ~F~
    no, i completely agree that the fire extinguisher should be up front... what i was refering to was helping getting into trunk if no battery power.... i dont think i'd fit through the pass-through....
  12. #12 Re: Fire Extinguisher mounted.
    Wichita, KS
    Ya, I hear ya. Its a stretch for me at that. Thank goodness I have long arms though.
    The little lever does the trick for what I need it to do. If one was creative enough, and had a lock assembly like this, just remove the t-handle, and run some cable through the lid, and down the hinge and on into the body of the car.
    For the ease of the install, and the money to be saved, I would probably use a universal bicycle brake cable or derailer cable for the line, and then get creative on a lever, and maybe have it hidden somewhere like under the front or rear of the drivers seat up out of the way, but yet assessable.
    All you would have to do is fab up a cable attachment to the trunk lock, and the lever. But there is plenty of different cable attachments from bicycles that would make that work easily, and cheaply if thats something you want to do.
    ~F~
  13. #13 Re: Fire Extinguisher mounted.
    GT Level Member drunknmunky's Avatar
    McDonough/Warner Robins, GA
    very clean install... i have mine in the trunk currently, and could see the problem that may come with that... i may look at installing mine somewhere else, it used to be on the hump in the back seat, between teh floorboards. but i moved it to the trunk and its been there since
  14. #14 Re: Fire Extinguisher mounted.
    GTX Level Member LowlyfeGTP's Avatar
    Janesville, WI
    Nice install Farns! Yeah mine is in the trunk as well. I have thought about mounting another one, but mine will probably be attached to the back of the center column. Remove the ashtray and install the bracket there or something along those lines.
    Jason Klingaman
    LOWLYFE
    99 GTP Silvermist Coupe
    360 vid
  15. #15 Re: Fire Extinguisher mounted.
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Looks like we're on the same page Farns! LOL, I just installed mine about three weeks ago.
    For all your 3800 needs:
  16. #16 Re: Fire Extinguisher mounted.
    Wichita, KS
    There ya go!
    I see you have broke off your little 12v power adapter plug as well. Stupid things I swear. I don't know how many of those I have went through myself.
    ~F~
  17. #17 Re: Fire Extinguisher mounted.
    Moore, Oklahoma
    Jason, where do you get those 12v plastic covers at? Dealer?
    Shawn W. Larsen
  18. #18 Re: Fire Extinguisher mounted.
    Wichita, KS
    You could.
    I find mine at the local salvage yard. Usually for free if I can remove it with out damaging the center console. The out let must be unscrewed from the inside/back side where you remove a threaded sleeve and then the main part pops out the front, and this is what holds the plastic cover on it, a little lip on the main part.
    I didn't start wearing them out until the power tuner came along.
    But When I bought my car, it was already broken and missing for me.
    ~F~
  19. #19 Re: Fire Extinguisher mounted.
    Wichita, KS
    Bump.
    ~f~
  20. #20 Re: Fire Extinguisher mounted.
    Ohio
    Looks really good. nice clean install. thinkin i might consider doing something long those lines in the future as well. And s far as the 12v outlet covers you guys were talking bout i never even had one it was broken when i got the car i didnt know it wasnt attached to the socket maybe ill go to the boneyard and pick up new one too
    00 GTP demodded and forsale
  1. How are your amps mounted?
    By archemedes in forum Audio, Security & Visual Electronics
    Last Post: 10-10-2009, 08:49 PM
  2. More vibration with new Wheels mounted
    By GeddyLee in forum Tires & Wheels
    Last Post: 04-24-2008, 09:57 PM
  3. GM Recalls 200,000 Sedans Over Fire Risk
    By 03GPScottyd in forum Off Topic Discussion
    Last Post: 03-16-2008, 08:04 AM
  4. No fire on #3 cyl, injector problems??
    By gplostinnd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2008, 12:28 AM
