Thread: fuel door spring bad
Results 1 to 7 of 7
  1. #1 fuel door spring bad
    GT Level Member hourang's Avatar
    commerce, mi
    my fuel door wont stay closed and opens on turns, lol. i know the spring is bad or missing, can i buy just the spring assembly? i know i can get the whole door from morad but would have to paint it black since they dont have a black one. i was thinking i could do something with velcro or some other rigged way to keep it shut?
    -Jeff
    98 GTP Black 4dr - fully loaded - short ram intake, tinted tails, hole in resonator.
    sold 98 camaro ss - 6spd fully loaded - cam, intake, exhaust, ford 9in rear 4.11s, 6point chromoly cage, tnt 150shot nitrous, nittos, etc.
  2. #2 Re: fuel door spring bad
    Willoughby, Ohio
    mine shuts but not all the way, you cant tell by looking at it until you mess with it. but i guess on the highway it flutters alot, so i hope you find an answer because im looking forward to it as well
  3. #3 Re: fuel door spring bad
    Jul 2010
    Michigan
    hey, did either of you two ever figure out how to replace just that piece? I just fixed my door hinge, but then the spring snapped. definitely not one of my happier moments.
  4. #4 Re: fuel door spring bad
    Jul 2011
    South Dakota
    I know this will sound crazy but one of my buddys had the same problem. we found one of those retractable lanyards and gorilla glued it to a couple pads of double sided 3m tape. worked for us.. good luck
  5. #5 Re: fuel door spring bad
    Jul 2010
    Michigan
    Quote Originally Posted by tc427 View Post
    No joke? That sounds like a pretty handy fix. Lol, anyway you can get a picture of that?
  6. #6 Re: fuel door spring bad
    commerce, mi
    nope traded the gtp in for a truck.
    -Jeff
  7. #7 Re: fuel door spring bad
    SE Level Member alacran's Avatar
    Apr 2008
    Chicago, IL
    I replaced the corroded spring last night. Pulling it out was easier than installing. I found a couple of good spring clips from the junk yard. The spring clips were removed as carefully as possible from the donor cars. I pulled 2 clips.
    When i installed the first clip it deformed really bad. For the second clip i had to drill out two rivets, remove two screws towards the front of gas cap, loosened the two screws at the rear, pulled the bolt out holding the latch to the plastic cover, and pull the door off.
    with the door off you can install or swap the spring clip in the closed position much easier than the open position. This is because the spring is not compressed as much "closed" than in the "open" position. This is why the door can flutter down the road.
    I suggest finding a really good spring for the swap and pulling the door. Another option is gluing a magnet in place somewhere maybe replacing one of the rubber stops with a magnet.
    That is my 2 cents!
  1. It's Spring in So. Cal.
    By surfinshell in forum West
    Last Post: 07-13-2009, 12:23 AM
  2. door locks/BCM/speaker/ door question
    By adamlesandrini in forum Audio, Security & Visual Electronics
    Last Post: 03-17-2009, 05:14 PM
