Thread: Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21 Re: Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    the sensor in the pan is for oil level. you shouldnt have to ever see that light because you check your dipstick every so often, right?
    the sensor on the oil pump housing is for oil pressure. if that light ever comes on it's too late because it only comes on when it sees less than 5psi and that's way too low. expect a new bottom end if you're seeing this light.
  2. #22 Re: Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    GT Level Member andremike's Avatar
    Nov 2009
    chicago
    The OP and myself are talking about the low oil level light on the right side of the cluster. This is the sensor in the oil pan that determines if you are low on oil.. And I did check my dipstick and there is plenty of oil in there..
    I guess I should of just left the old sensor in there...
  3. #23 Re: Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    Nov 2009
    chicago
    Any other ideas? Bringing my car in for the third time..
  4. #24 Re: Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    Apr 2011
    Cleveland, Ohio
    I have a 97 Grand Prix with the exact same problem.. the oil level light sometimes comes on but never when I restart the engine again.. changing the sensor nor the connector helped.. Has anyone found the solution? Thanks
  5. #25 Re: Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Have the same problem with the 98, exact symptoms. Replaced the sensor and no change.
    Sent from my SPH-L720 using Tapatalk
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  6. #26 Re: Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    Dec 2013
    Enfield
    Maybe next oil change do a Risolene engine flush before changing the oil. If this is somehow caused by a sludge build up condition it could help, either way wont hurt and it only puts you out about 5 bucks.
  7. #27 Re: Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    Dec 2008
    ****'s Creek
    No sludge on the 98, I only changed the sensor because I changed the pan and gasket.
  8. #28 Re: Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Changed the pan? Nice. Thats not as simple as it sounds.
    I have gone through 2 oil sending units since this original post. Seems to take care of the problem for a good while.
    Also the 20w-50 was just an experiment (mechanic had me come by and check oil pressure a few times to see what was going on). Next oil change went back to 10-30 and replaced sender the first time.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  9. #29 Re: Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    Dec 2011
    Okc
    I am having this exact same problem.
    My oil level notice in my 2007 would come on a few times a week at startup. I change the sensor and now it comes on everytime its cold. It doesn't do it when the engine is warm.
    The replacement was a brand new acdelco unit. Any suggestions on how to clean the connector to the sensor? It's the only thing I can think that might help.
  10. #30 Re: Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    Newnan, GA
    Just to update this as my case was resolved 100%.
    Apparently I hit something dead center on the oil pan. This damaged the oil pickup.
    The pressure was verified with a mechanical guage. Low after 3,000 miles on castrol 10-30 synthetic high mileage. Normal after oil change with the same stuff.
    Damaged pick up caused the top oil in the pan to immediately go back into the engine. Wearing out the oil much faster than normal. Thus causing the low pressure.
    So, by looking at my earlier post as a start date, I drove it 60,000 miles like that. Then traded it in.
    Sent from my SM-G920P using Tapatalk
  11. #31 Re: Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    Dec 2011
    Okc
    Quote Originally Posted by EJOUIE View Post
    Are you saying the low oil sensor has anothing to do with the oil level in your case, and just was just based on low pressure?
  12. #32 Re: Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    Newnan, GA
    No. I had the red low oil pressure light.
    The low oil level sensor was surprisingly accurate.
  13. #33 Re: Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    Dec 2011
    Okc
    So over a year later, we figure out that this is the red oil 'pressure' light.... while the title says 'low oil level light' and 'low oil level sensor' and no mention of 'pressure'?
    So this has nothing to do with the title and is actually about an entirely different issue? Well so much for following this thread in hopes of resolving my issue.
  14. #34 Re: Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    Dec 2008
    ****'s Creek
    Back on topic regarding Low oil LEVEL sensor, I had an idea that maybe worth trying....I sold the 98 sedan so my immediate issue is fixed....BUT....if you look at the sensor, it's basically an arm with a float on the end, essentially a float switch. I wonder if it's possible to install the switch so that it's 180* off? In other words upside down? Or if it's possible to thread it in so that the float is not exactly perpendicular to the oil level? Depending on how the threads are cut on the switch and/or pan, it may be possible to start it incorrectly so that when it threads in it winds up in the wrong orientation. Thi is just a SWAG in my part, but what else would explain it?
    Other theory is that the wiring is fragile and by unplugging/plugging in the new sensor the wiring gets damaged.
  15. #35 Re: Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    SE Level Member RonsGTP's Avatar
    Apr 2015
    San Antonio, Texas
    My light recently started coming on too but when I check the oil its within range, only needing maybe half a quart so I topped it off but guess I really didn't have to.
    1999 Black GTP (stock)
    2017 ZL1 (Red Hot)
    2016 Camaro SS (wife's car)
  1. at what mod level do i upgrade TB?
    By AmericanSoldier in forum General Tech Discussion
    Last Post: 03-23-2010, 01:12 PM
  2. Next Level STB's
    By 04CompG in forum Brakes/Suspension/Chassis
    Last Post: 11-23-2008, 05:45 PM
  3. Oil Level??
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2008, 08:15 AM
  4. oil level low
    By johnnyj773 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-07-2008, 03:10 AM
  5. GTP Level member
    By IndeedSS in forum Off Topic Discussion
    Last Post: 03-10-2008, 10:16 PM
