Thread: at what mod level do i upgrade TB?
Results 1 to 18 of 18
AmericanSoldier at what mod level do i... 02-09-2010, 04:11 PM
matt5112 Re: at what mod level do i... 02-09-2010, 04:15 PM
Bio248 Re: at what mod level do i... 02-09-2010, 04:20 PM
Lawngoose Re: at what mod level do i... 02-09-2010, 04:28 PM
03GTPLE Re: at what mod level do i... 02-09-2010, 04:45 PM
QwikGT Re: at what mod level do i... 02-09-2010, 04:20 PM
Bio248 Re: at what mod level do i... 02-09-2010, 04:22 PM
matt5112 Re: at what mod level do i... 02-09-2010, 04:24 PM
AmericanSoldier Re: at what mod level do i... 02-26-2010, 09:40 AM
Bio248 Re: at what mod level do i... 02-26-2010, 10:25 AM
03GTPLE Re: at what mod level do i... 03-01-2010, 11:46 AM
99prixgt Re: at what mod level do i... 02-27-2010, 01:05 AM
minichopper6hp Re: at what mod level do i... 02-27-2010, 01:48 AM
AmericanSoldier Re: at what mod level do i... 03-01-2010, 11:43 AM
Bio248 Re: at what mod level do i... 03-01-2010, 11:44 AM
minichopper6hp Re: at what mod level do i... 03-01-2010, 11:44 AM
Bio248 Re: at what mod level do i... 03-01-2010, 11:51 AM
AmericanSoldier Re: at what mod level do i... 03-23-2010, 01:12 PM
  1. #1 at what mod level do i upgrade TB?
    GTP Level Member
    Nov 2008
    MA
    i was leaning towards zzps stage 1..ive searched on mulitple forums but couldnt find when our cars TB gets limited flow..at the moment my mods are as follows
    plog, 3" dp, magnaflow cat back, 3.5 s/c pulley, overkill pcm, 1.95 rr, 90 # springs, CAI, 104's and 180 t stat
    thanks!
    03 GTP - 13.8 @ 100 2.160ft
    99 GTP - DD
    *Operation Iraqi Freedom/Operation New Dawn Veteran*
  2. #2 Re: at what mod level do i upgrade TB?
    Get a cam, headers, ported blower and then maybe you'd need a new TB.
    ZZ's stage one and two TB's tend to idle like **** from what I've heard. Just go for the LS1 throttle body.
  3. #3 Re: at what mod level do i upgrade TB?
    there is no reason to ever buy a modded stock throttle body when it takes a half hour to hog one out yourself. if youre going to buy one buy the ZZP 78mm TB, a northstar setup, or an ls1 setup. i never liked the feel of any of them, but the stocker so thats why i just ported mine by myself.
    you dont really need a bigger throttle body until you get to the 3.0 pulley area, which is usually achieved with an intercooler and rockers/cam. even then its not going to net you that much power if any at all.
  4. #4 Re: at what mod level do i upgrade TB?
    Outer Space
    I agree... however, I had to change from my 3" FWI to a 4" .... since I am cammed and its choking, I am going to have start looking for a new MAF since im starting to Max it out now. Never had this issue, until i went cammed and put on the 3.3"
    02 GTP 13.6 @ 100mph - SOLD
  5. #5 Re: at what mod level do i upgrade TB?
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    Is there a good write up with pics showing what to hog out somewhere?
    THANKS!
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  6. #6 Re: at what mod level do i upgrade TB?
    May 2008
    staten island,NY
    dont waste money on the stage ones, just buy a northstar, you will need a tune because the maf sensor is moved, as well as an extension harness for the IAT sensor. a new intake like i have on my car would be a good idea too. you will notice better throttle response, plus now you have an inline maf not a fruity one like stock
  7. #7 Re: at what mod level do i upgrade TB?
    you do not get throttle response from a northstar. i wish people would stop saying that.
    the northstar setup has a linear plate movement while the stock setup is progressive (opens less with less throttle, more with more throttle). i hate the feel of the linear plate movement as youre into boost by touching the pedal with your big toe. HATED it.
  8. #8 Re: at what mod level do i upgrade TB?
    I can see how linear would be nice for a decent N/A engine but not if you're boosted.
  9. #9 Re: at what mod level do i upgrade TB?
    GTP Level Member
    Nov 2008
    MA
    isnt there a guy on here named reptile that ports TB's for a good price?
    99 GTP - DD
  10. #10 Re: at what mod level do i upgrade TB?
    yes, but its so easy to do on your own. in fact, if you sent me a throttle body with $20 taped to it id do it for you. it takes like an hour.
  11. #11 Re: at what mod level do i upgrade TB?
    Tyler, TX
    Do have any pics of what we are supposed to do? I've got a dremmel and access to a die grinder. I haven't taken the TB off to look at it to see what's needed.
    Are you talking about knocking down walls, just smoothing somthing down, or enlarging the bore?
    THANKS!
  12. #12 Re: at what mod level do i upgrade TB?
    Jersey
    I like the N* feel at part throttle, you barely have to touch the gas. Its kind of stupid though when you feel you give 80% then you go 100% and the car doesn't go any faster.
    16' wrx sti- stock
  13. #13 Re: at what mod level do i upgrade TB?
    Banned - Busted For Scamming
    Feb 2009
    Doesnt matter anyways, the pcm around 80% throttle just goes into WOT fueling anyways.
  14. #14 Re: at what mod level do i upgrade TB?
    GTP Level Member
    Nov 2008
    MA
    if i get my stock tb ported will i need to get it re tuned?
    99 GTP - DD
  15. #15 Re: at what mod level do i upgrade TB?
    your MAF table will be off, so yes.
  16. #16 Re: at what mod level do i upgrade TB?
    Feb 2009
    Best to but not completely necessary.
  17. #17 Re: at what mod level do i upgrade TB?
    on the stock throttle body you cant enlarge it much more than stock without breaking through the outside of the casting, which youll probably do in some areas anyway since its so thin to begin with. if you look down the throttle body, any part that is exposed farther out than the overall diamter of the casting youre going to want to smooth out so it is completely round. the main thing here that is in the way is going to be the MAF hump in the upper center.
    when you start taking material away, youll break through the casting like the majority of us have when porting. i just used some aluminum epoxy and smoothed everything out so it was round and straight through with nothing exposed in the way of the air path. other than that just smooth everything out and let it be. you can enlarge the backside of the throttle body that is behind the throttle plate, but it only helps if the blower is machined out to be the same size so i left mine alone. make sure you DO NOT touch anything near where the throttle plate will seal.
  18. #18 Re: at what mod level do i upgrade TB?
    GTP Level Member
    Nov 2008
    MA
    this is all good to know thanks all
    99 GTP - DD
  1. oil level above than normal?
    By kind153 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-03-2010, 01:37 AM
  2. Next Level STB's
    By 04CompG in forum Brakes/Suspension/Chassis
    Last Post: 11-23-2008, 05:45 PM
  3. Oil Level??
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2008, 08:15 AM
  4. oil level low
    By johnnyj773 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-07-2008, 03:10 AM
  5. GTP Level member
    By IndeedSS in forum Off Topic Discussion
    Last Post: 03-10-2008, 10:16 PM
