Maybe I just have bad luck, but every kind of battery terminal I've tried so far has failed to stay useable for longer than a year.
The original flat plate clamp with the tapered nut broke off when I dropped an alternator on it. I tried a new one of the same style and the stud stripped before it even got tight on the post.
The lead-free soft metal ones have either deformed so much that they don't even clamp onto the post, or they split at the bolt, or they just break in half.
My last ones were marine terminals, with some really sturdy paint that looks great, but the negative one has been removed maybe 10 times and is already so enlarged that it'll slide right over the post, even though its as tight as I can make it.
What other designs/material are there, that can withstand repeated removals and reinstallations, can withstand being smacked or stuff being dropped on it, looks good, and provides a really good connection.
The battery doesn't have side posts, or threaded holes, else I would have already just bolted the cables to the damn thing and been done a long time ago. I'm not replacing it until it fails, which will be a long, long time with how it's doing so far.
I'm planning on doing some other electrical upgrades, but right now I need a decent connection with the battery.
I'm open to building my own if that's what it'll take...
