Thread: Best design for battery terminals?
Results 1 to 6 of 6
  1. #1 Best design for battery terminals?
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Maybe I just have bad luck, but every kind of battery terminal I've tried so far has failed to stay useable for longer than a year.
    The original flat plate clamp with the tapered nut broke off when I dropped an alternator on it. I tried a new one of the same style and the stud stripped before it even got tight on the post.
    The lead-free soft metal ones have either deformed so much that they don't even clamp onto the post, or they split at the bolt, or they just break in half.
    My last ones were marine terminals, with some really sturdy paint that looks great, but the negative one has been removed maybe 10 times and is already so enlarged that it'll slide right over the post, even though its as tight as I can make it.
    What other designs/material are there, that can withstand repeated removals and reinstallations, can withstand being smacked or stuff being dropped on it, looks good, and provides a really good connection.
    The battery doesn't have side posts, or threaded holes, else I would have already just bolted the cables to the damn thing and been done a long time ago. I'm not replacing it until it fails, which will be a long, long time with how it's doing so far.
    I'm planning on doing some other electrical upgrades, but right now I need a decent connection with the battery.
    I'm open to building my own if that's what it'll take...
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  2. #2 Re: Best design for battery terminals?
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    All the salt and crap got ya down? These work great up here. Friend has some on his '86 full-size Blazer. Holding up real good.
    https://www.google.com/search?q=car+...w=1680&bih=941
    Last edited by SaukRapids; 04-26-2017 at 09:05 PM. Reason: I dint lern to type in skool>
  3. #3 Re: Best design for battery terminals?
    Oct 2014
    Frederick, MD
    Alaska doesn't use any salt on any roads, because it gets so cold that ice won't melt anything, just turn it into really slick ice.
    I'm kinda wary of having a huge block of brass hanging off just the post... But there doesn't seem to be much else that's better.
  4. #4 Re: Best design for battery terminals?
    Oct 2014
    Frederick, MD
    Ok, so the marine terminal design is probably the one I'm going to use, just because it's simple and I'll switch over to wingnuts instead of nyloc nuts to hold the cables to the terminals...
    I just need to find the best material. Lead, Zinc, Brass, or mild steel?
  5. #5 Re: Best design for battery terminals?
    Jul 2010
    Coquitlam,BC,Canada
    I used this style on my Bronco....
    They clamped nice and tight on the wire and the post; never gave me issues.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #6 Re: Best design for battery terminals?
    Oct 2014
    Frederick, MD
    Well I went with zinc terminals, and the same marine style that I had before. I'll keep the terminals on those posts, and just use the wingnut to disconnect it when I dig into the electrical system again later. It'll do for now.
    But I'm planning on doing some upgrades to the entire system eventually, to include a CS144 alternator, some much heavier battery cables, a proper ground block, with some decent mounting reinforcement and plenty of connection points. Might do a positive connection block as well, still thinking about it.
  1. battery to starter terminals
    By Jason97GrandprixGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-07-2015, 08:23 PM
  2. Replies: 12
    Last Post: 11-18-2013, 04:43 AM
  3. Battery Terminals
    By gordster1122 in forum General Tech Discussion
    Last Post: 07-19-2013, 07:48 PM
  4. converting tranny cooler lines from 1st design to 2nd design
    By tonglebeak in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-22-2012, 08:16 PM
  5. 1st Design or 2nd Design Water Pump?
    By BlackGT1 in forum General Tech Discussion
    Last Post: 04-22-2012, 11:16 PM
