Thread: Could THIS Be Causing All of the Engine Fires?
Page 3 of 3 FirstFirst 123
Results 41 to 53 of 53
SuperSport Could THIS Be Causing All of... 04-11-2010, 10:41 PM
Warbeaver Re: Could THIS Be Causing All... 04-11-2010, 10:52 PM
SuperSport Re: Could THIS Be Causing All... 04-11-2010, 10:58 PM
Rather B Blown Re: Could THIS Be Causing All... 04-12-2010, 01:09 AM
QUICKSILVER462 Re: Could THIS Be Causing All... 04-12-2010, 10:50 AM
kjohnson Re: Could THIS Be Causing All... 04-12-2010, 10:57 AM
Warbeaver Re: Could THIS Be Causing All... 04-12-2010, 11:30 AM
SuperSport Re: Could THIS Be Causing All... 04-12-2010, 01:54 PM
matt5112 Re: Could THIS Be Causing All... 04-12-2010, 02:35 PM
SuperSport Re: Could THIS Be Causing All... 04-12-2010, 02:41 PM
Warbeaver Re: Could THIS Be Causing All... 04-12-2010, 03:50 PM
SuperSport Re: Could THIS Be Causing All... 04-12-2010, 03:56 PM
matt5112 Re: Could THIS Be Causing All... 04-12-2010, 09:16 PM
Lawngoose Re: Could THIS Be Causing All... 04-12-2010, 09:26 PM
Lonestargp Re: Could THIS Be Causing All... 04-14-2010, 09:50 PM
SuperSport Re: Could THIS Be Causing All... 04-25-2010, 06:23 PM
matt5112 Re: Could THIS Be Causing All... 04-25-2010, 07:08 PM
SuperSport Re: Could THIS Be Causing All... 04-25-2010, 07:16 PM
matt5112 Re: Could THIS Be Causing All... 04-26-2010, 02:30 PM
BDEGhost Re: Could THIS Be Causing All... 04-25-2010, 07:24 PM
SuperSport Re: Could THIS Be Causing All... 04-25-2010, 07:25 PM
Warbeaver Re: Could THIS Be Causing All... 04-26-2010, 01:58 PM
relivenyouth Re: Could THIS Be Causing All... 10-04-2011, 12:20 PM
txslow6 Re: Could THIS Be Causing All... 10-04-2011, 01:21 PM
matt5112 Re: Could THIS Be Causing All... 10-04-2011, 01:23 PM
relivenyouth Re: Could THIS Be Causing All... 10-04-2011, 01:55 PM
16MustangVet Re: Could THIS Be Causing All... 10-04-2011, 02:48 PM
TLSheff Re: Could THIS Be Causing All... 10-04-2011, 04:10 PM
relivenyouth Re: Could THIS Be Causing All... 10-04-2011, 01:57 PM
txslow6 Re: Could THIS Be Causing All... 10-04-2011, 11:59 PM
codyAK Re: Could THIS Be Causing All... 10-04-2011, 04:50 PM
16MustangVet Re: Could THIS Be Causing All... 10-04-2011, 05:32 PM
relivenyouth Re: Could THIS Be Causing All... 10-04-2011, 06:01 PM
relivenyouth Re: Could THIS Be Causing All... 10-07-2011, 07:17 PM
goldgp Re: Could THIS Be Causing All... 10-07-2011, 08:09 PM
sic6 Re: Could THIS Be Causing All... 10-08-2011, 08:38 AM
garagedoorman Re: Could THIS Be Causing All... 10-22-2011, 11:38 AM
Burbman Re: Could THIS Be Causing All... 04-25-2013, 12:36 PM
Scottydoggs Re: Could THIS Be Causing All... 04-25-2013, 12:39 PM
Burbman Re: Could THIS Be Causing All... 04-25-2013, 10:06 PM
Burbman Re: Could THIS Be Causing All... 04-25-2013, 08:08 PM
Scottydoggs Re: Could THIS Be Causing All... 04-25-2013, 08:12 PM
lostscout Re: Could THIS Be Causing All... 04-27-2017, 11:30 AM
BillBooost37 Re: Could THIS Be Causing All... 04-27-2017, 06:40 PM
  1. #1 Re: Could THIS Be Causing All of the Engine Fires?
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Dorman 800-059 is the rear line, the splice was a ton easier than trying to perform micro-surgery on those O-rings....just a simple barb fitting connects the new line to the old.
  2. #2 Re: Could THIS Be Causing All of the Engine Fires?
    Dec 2008
    ****'s Creek
    I got the $10 Viton o-rings and I must have scratched the inside of the connector....it leaks no matter I do. Going to plan B with the Dorman nylon line that I can splice in.
  3. #3 Re: Could THIS Be Causing All of the Engine Fires?
    does it click when you push it on, then move with no fuel pressure on the line yet, like back and fourth? its should.
    you may have the wrong O ring in there, mine fell apart when i took them out, it was pretty hard to match up the new ones. i used the wrong larger one the first time around.
    the smaller one was about the size of the rail end too.
  4. #4 Re: Could THIS Be Causing All of the Engine Fires?
    SE Level Member lostscout's Avatar
    Sep 2014
    Cold Lake Alberta Canada
    my theory on why these cars burn...the cat plugs up, forcing extra hot exhaust up thru the stovepipe, melting the UI and the plastic gas line right on top of the manifold
  5. #5 Re: Could THIS Be Causing All of the Engine Fires?
    Mar 2017
    Internet
    Sorry.. I don't buy it.
    Especially since GM changed the stove pipe design from having almost no clearance to the manifold to having a lot. and the only harm that did was the heat cycles of the plastic manifold would cause the manifold to crack quicker. Which..in turn allowed coolant to fill the intake of the motor. No fire from that.
  1. Heavy stutter under boost, but no mis-fires
    By 007 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2010, 12:46 AM
  2. What's causing this?
    By BwolfGT in forum General Tech Discussion
    Last Post: 10-02-2009, 04:57 PM
  3. 97 fires but wont run.
    By clh97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-20-2009, 10:08 PM
  4. What is causing my MAF to go out?
    By MartinTD in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-30-2009, 04:33 PM
  5. Hub Assembly causing thunk?
    By Deezul_AwT in forum Tires & Wheels
    Last Post: 03-28-2008, 07:36 PM
