Thread: Could THIS Be Causing All of the Engine Fires?
Results 1 to 20 of 53
  1. #1 Re: Could THIS Be Causing All of the Engine Fires?
    Have the same issue.
    Its all about the quick disconnects.
    You can check your O-rings or replace with AN fittings like so:
    http://www.grandprixforums.net/fuel_line.php
    http://www.grandprixforums.net/f73/c...html#post82837
    Pics in the second link.
  2. #2 Re: Could THIS Be Causing All of the Engine Fires?
    GTP Level Member SuperSport's Avatar
    Michigan
    So youre saying broken o-rings are not the problem? Interesting.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  3. #3 Re: Could THIS Be Causing All of the Engine Fires?
    Donating Users Warbeaver's Avatar
    St. Louis
    Couldn't tell ya exactly which one it was warbeaver, but you will need 2 packs of those anyways. The feed and return lines have 2 o-rings in each, and one line is large with 2 larger o-rings and one line is small with 2 smaller o-rings
    so..ur replacing the yellow o-rings too? i thought you were only replacing 1 o-ring in each line? the brown ones...
  4. #4 Re: Could THIS Be Causing All of the Engine Fires?
    Michigan
    Quote Originally Posted by Warbeaver View Post
    I changed both yellow and brown in both lines for good measure. Although the yellow rings were not in as bad of shape as the brown ones, they were very soft and in need of changing.
  5. #5 Re: Could THIS Be Causing All of the Engine Fires?
    St. Louis
    when you replace injector o-rings do you usually replace both the ones on the bottom of the injector and the top, or just the bottom? If you want to pull the injectors out of the fuel rails, do they just pull out? and you just slip them back in with the new o-rings?
  6. #6 Re: Could THIS Be Causing All of the Engine Fires?
    Michigan
    When you pop off the fuel rail, there is a metal slip retainer at the top of the injector that holds the injector in the rail. Slide that sleeve out and then the injector can be pulled out of the rail.
    It is recommended to change top and bottom o-rings. As for buying injector o-rings, just ask at the parts counter. There are 12 in a pack I believe. Enough to do top and bottom.
  7. #7 Re: Could THIS Be Causing All of the Engine Fires?
    Wichita
    Because if you don't replace all your injectors you risk getting a nasty vacuum leak or worse.
  8. #8 Re: Could THIS Be Causing All of the Engine Fires?
    No, I'm saying if they had brass fittings, this wouldn't be an issue.
    Quick disconnects aren't a smart thing to use since they rely on rubber o-rings.
  1. Heavy stutter under boost, but no mis-fires
    By 007 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2010, 12:46 AM
  2. What's causing this?
    By BwolfGT in forum General Tech Discussion
    Last Post: 10-02-2009, 04:57 PM
  3. 97 fires but wont run.
    By clh97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-20-2009, 10:08 PM
  4. What is causing my MAF to go out?
    By MartinTD in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-30-2009, 04:33 PM
  5. Hub Assembly causing thunk?
    By Deezul_AwT in forum Tires & Wheels
    Last Post: 03-28-2008, 07:36 PM
