Thread: White smoke
Results 1 to 11 of 11
  1. #1 White smoke
    yuma, az
    I have a 1997 Pontiac grand prix gt 3.8...there is white smoke coming out of the tails pipe..i fixed the LIM and the UIM penilum(spelling), however same problem exist, there is no water in the oil, the engine did not get hot,please. advise what else could be the problem?Thank you.
  2. #2 Re: White smoke
    Apr 2009
    stockton ca
    headgaskets maybe
  3. #3 Re: White smoke
    Largo, Florida, United States
    are your spidey senses tingling?
    but Headgasket sounds about dead on.
  4. #4 Re: White smoke
    yuma, az
    Is it the egr pipe that goes bad and has to be replaced or is it the plastic housing around it? Can someone tell me what parts I need besides gaskets to fix this problem. I do not believe it is the head gaskets but rather lack of knowledge that has prolonged my misery.
  5. #5 Re: White smoke
    swift current,sask.
    How is the pressure in the coolant hose when you start it cold? I'm assuming the smoke smells sweetish?
  6. #6 Re: White smoke
    Jul 2008
    sumter,south carolina
    rings?
    02 GTP with mods 05 GP for DD
  7. #7 Re: White smoke
    Donating Users
    South Deerfield, MA
    When you did the lim gasket job, did you find a lot of coolant in the intake manifold? When the intake manifold melts around the EGR inlet it lets coolant pour into your intake manifold and go into the engine. I know somebody with a buick that took the time to rip everything apart and change the head gaskets only to find it was still burning coolant. Turned out to be the intake manifold had melted around the EGR inlet. If that is the problem go to rockauto.com and get the Dorman replacement upper intake manifold. It comes with all the gaskets to do the job and is only about $80. It is very common on the 3.8 to have this happen.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  8. #8 Re: White smoke
    yuma, az
    OK, sounds like upper intake manifold, which was not replaced, the car ran fine after we changed LIM UIM gaskets got all H20 out then ran it, white smoke increase. I shut it down did not get hot hopefully the engine did not suffer internal damage. Oil is free of coolant. Coolant low as it has pored into the engine so now I will clear out the coolant again, clean plugs, replace intake manifold. thanks for info.
  9. #9 Re: White smoke
    Kansas
    UIM (upper intake manifold) ?
    SOLD 1999 GT Silvermist TS
  10. #10 Re: White smoke
    yuma, az
    Yes UIM, Is the dorman better than the cordone ?
  11. #11 Re: White smoke
    yuma, az
    thanks for the help I replace pelum tube no more white smoke motor sounds good, now I need to figure out the vacuum system any pics on here that could help me out.
    D
  1. White smoke
    By dhaller in forum General Tech Discussion
    Last Post: 04-10-2010, 06:29 PM
  2. Jerking and white smoke
    By jhnath in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-01-2009, 12:51 AM
  3. White smoke problem
    By SilverGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-05-2009, 10:24 AM
  4. SES light/White smoke
    By fudhimself in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-29-2009, 10:30 PM
  5. Replacing Blower Motor---Puff of white smoke
    By Burgundyman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-08-2009, 06:46 AM
