Thread: Car going into storage, advice?
Results 1 to 18 of 18
  1. #1 Car going into storage, advice?
    Apr 2009
    Wausau, Wisconsin
    Hey guys I need some advice..
    I am leaving for Basic on August 18th and my gt will be sitting until December. I have permission to put it in my Grandmothers garage for the time but what kind of work should I do to the car before then?
  2. #2 Re: Car going into storage, advice?
    Apr 2009
    stockton ca
    id put fresh oil in it some stabilizer in the gas tank and pull the battery
    id also do a quick detail on it
  3. #3 Re: Car going into storage, advice?
    Nov 2008
    Waterloo, Iowa
    I heard you need to do something with tires. Possibly has to do with forming flat spots or such. I don't recall, just pointing it out as something to look into.
  4. #4 Re: Car going into storage, advice?
    SE Level Member bt06gpturbo's Avatar
    Feb 2010
    Connersville
    same as torque auto or u could get a battery tender and leave it on that...jus do ur basic car care clean it up fresh oil get some injector cleaner and run that through and it sounds like this seafoam would be a great idea
  5. #5 Re: Car going into storage, advice?
    Apr 2009
    stockton ca
    www.TechGuys.ca | How to: Store a car for winter
    theres some good stuff in here i think he takes it a bit far but alot of it makes sense
    like releaving fuel pressure and blocking exhaust passages
  6. #6 Re: Car going into storage, advice?
    Fort Atkinson
    Stabil in the tank, change the oil when you get back to it in december, battery tender and put it on jack stands if you're worried about flat spots on the tires.
  7. #7 Re: Car going into storage, advice?
    Largo, Florida, United States
    any chance you could have someone start and drive it like once every 2 weeks
  8. #8 Re: Car going into storage, advice?
    Apr 2009
    Wausau, Wisconsin
    Maybe, does it really make that big of a difference?
  9. #9 Re: Car going into storage, advice?
    GTX Level Member cerick08GP's Avatar
    Quote Originally Posted by Stunt0Rider View Post
    Just leave it sit, every start gives more wear.
    Being ex-military I had to leave my cars for months many times. Not once, or twice, many times. Since you have a garage lined up you are 90% there. Honestly, the only thing that really needs to be done is to disconnect the battery. That is it, just make sure the wires are secured after disconnecting. Another big tip is clean all the crap out of the interior. All food, containers, CDs, cloths, etc. I also firmly believe in having a ~7/8 full tank of gas, and pop in some Seafoam if you remember. And sure, change your oil just before definitely wouldn’t hurt.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  10. #10 Re: Car going into storage, advice?
    Apr 2009
    stockton ca
    fresh oil before hand not after
  11. #11 Re: Car going into storage, advice?
    SE Level Member basballny2's Avatar
    New York
    Quote Originally Posted by TorqueAutoMotiv View Post
    agreed, when the oil gets used and sits in the motor it becomes acidic....i would just change the oil and put some stabil in a FULL tank. either pull the battery or tender it and toss some dryer freshners in there to keep the smell out. put some mouse traps under the car as well.
  12. #12 Re: Car going into storage, advice?
    SE Level Member nault31's Avatar
    Southside Chicago Suburbs
    I read a thing on this in Popular Mechanics a few months back, basically you only have to worry about unplugging the battery and putting it on a tender, changing oil, stabilizing fuel, and your worst enemy rodents. I left a car sit for 2 days in my garage last fall and found a mouse nest on top of the engine under the cover. Take off the engine cover and stuffing the exhaust doesn't sound bad along with mouse traps. Some go nuts with moth balls or something to keep them out of the interior vents or buying a car cover but that's up to you.
    ^^I realize a stock L36 is not as fast as the sticker implies, but this sticker has worked and it is still a hell of a lot of fun to drive considering it's a grocery sedan.
  13. #13 Re: Car going into storage, advice?
    New York
    without traps to catch them your brand new car cover will turn into a brand new nest for them. you'll come back and half your cover will be gone. put traps.....lots of them
  14. #14 Re: Car going into storage, advice?
    Apr 2009
    Wausau, Wisconsin
    Here is what I plan on doing so far..
    A complete tune up over the next 2 months.
    Pull Battery.
    Fuel Stable.
    Dryer Sheets
    Moth Balls
    Steel Wool in the Exhaust.
    Complete Detail
    Cover
    Do you guys think a tarp over the cover would help with chewing?
  15. #15 Re: Car going into storage, advice?
    Apr 2009
    stockton ca
    na tarp mwont do much just put down a few sticky traps around the wheels
    i mean i had a truck sat behind my friends house for 2 years it was covered i did tune and oil change before hand go back to cali untarped it threw a new battery in it and she fired and ran fine he had a pest control service so i was rodent safe
  16. #16 Re: Car going into storage, advice?
    New York
    na all a tarp is going to do is keep moisture in. if its in a garage and u have a cover on it your fine. MOST covers nowadays dont allow moisture to build up because they "breathe" putting a tarp over that will leave the moisture trapped there.
  17. #17 Re: Car going into storage, advice?
    Good luck in Basic Young Private.
    Just remeber
    Even if your right, To a Drill SGT your wrong.
    Never talk or ask the DS a question unless its life,limb, or eye sight (Or training related)
    avoid sick call. & profiles (Your platoon will hate you)
    and work your ass off at PT and keep it up
  18. #18 Re: Car going into storage, advice?
    Apr 2009
    stockton ca
    Just remeber
    also stay in the middle never be first or last you dont want them learning your name too fast
    dont eat desserts or drink sodas in chow hall
    dont expect your gf to wait for you
    never misplace your weapon or take your eye off it sounds stupid but i saw a ton of stupid crap in basic
  1. Do u winter storage?????
    By timmaayy2323 in forum How To Write-Ups/Tech Tips
    Last Post: 11-20-2009, 09:24 PM
  2. I'm the New Guy, Looking for Advice
    By 98 DAYTONA in forum Introductions/Noob Questions
    Last Post: 06-04-2009, 09:47 AM
  3. Car Storage
    By Damojo2003 in forum Off Topic Discussion
    Last Post: 01-02-2009, 08:50 AM
  4. need a little advice
    By adsgp09 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-30-2008, 07:24 PM
  5. Repairing plastic storage case?
    By Toasty in forum Off Topic Discussion
    Last Post: 05-16-2008, 11:14 PM
