Hey guys I need some advice..
I am leaving for Basic on August 18th and my gt will be sitting until December. I have permission to put it in my Grandmothers garage for the time but what kind of work should I do to the car before then?
id put fresh oil in it some stabilizer in the gas tank and pull the battery
id also do a quick detail on it
same as torque auto or u could get a battery tender and leave it on that...jus do ur basic car care clean it up fresh oil get some injector cleaner and run that through and it sounds like this seafoam would be a great idea
www.TechGuys.ca | How to: Store a car for winter
theres some good stuff in here i think he takes it a bit far but alot of it makes sense
like releaving fuel pressure and blocking exhaust passages
Stabil in the tank, change the oil when you get back to it in december, battery tender and put it on jack stands if you're worried about flat spots on the tires.
fresh oil before hand not after
Just leave it sit, every start gives more wear.
Being ex-military I had to leave my cars for months many times. Not once, or twice, many times. Since you have a garage lined up you are 90% there. Honestly, the only thing that really needs to be done is to disconnect the battery. That is it, just make sure the wires are secured after disconnecting. Another big tip is clean all the crap out of the interior. All food, containers, CDs, cloths, etc. I also firmly believe in having a ~7/8 full tank of gas, and pop in some Seafoam if you remember. And sure, change your oil just before definitely wouldn’t hurt.
agreed, when the oil gets used and sits in the motor it becomes acidic....i would just change the oil and put some stabil in a FULL tank. either pull the battery or tender it and toss some dryer freshners in there to keep the smell out. put some mouse traps under the car as well.
I read a thing on this in Popular Mechanics a few months back, basically you only have to worry about unplugging the battery and putting it on a tender, changing oil, stabilizing fuel, and your worst enemy rodents. I left a car sit for 2 days in my garage last fall and found a mouse nest on top of the engine under the cover. Take off the engine cover and stuffing the exhaust doesn't sound bad along with mouse traps. Some go nuts with moth balls or something to keep them out of the interior vents or buying a car cover but that's up to you.
without traps to catch them your brand new car cover will turn into a brand new nest for them. you'll come back and half your cover will be gone. put traps.....lots of them
na tarp mwont do much just put down a few sticky traps around the wheels
i mean i had a truck sat behind my friends house for 2 years it was covered i did tune and oil change before hand go back to cali untarped it threw a new battery in it and she fired and ran fine he had a pest control service so i was rodent safe
na all a tarp is going to do is keep moisture in. if its in a garage and u have a cover on it your fine. MOST covers nowadays dont allow moisture to build up because they "breathe" putting a tarp over that will leave the moisture trapped there.
Good luck in Basic Young Private.
Just remeber
Even if your right, To a Drill SGT your wrong.
Never talk or ask the DS a question unless its life,limb, or eye sight (Or training related)
avoid sick call. & profiles (Your platoon will hate you)
and work your ass off at PT and keep it up
also stay in the middle never be first or last you dont want them learning your name too fast
dont eat desserts or drink sodas in chow hall
dont expect your gf to wait for you
never misplace your weapon or take your eye off it sounds stupid but i saw a ton of stupid crap in basic
