Thread: gauge recommendations.
Results 1 to 6 of 6
  1. #1 gauge recommendations.
    Joliet, IL
    so i have a 3 gauge pod where my DIC used to me on my dash molded in...
    im going to fill it with a Aeroforce, AEM Uego, and Autometer ES boost.
    i also have a lower dash cubby with 2 gauge holes....currently in FS section.
    should i keep the lowers and put a fuel pressure and oil pressure setup? or are my 3 gauges up top enough to have for a dialed in tune/3.2 or 3.4 e85 setup?
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: gauge recommendations.
    Banned - Busted For Scamming
    Feb 2009
    You want a oil pressure gauge trust me.
  3. #3 Re: gauge recommendations.
    oil pressure, wide band, fuel pressure.
    then get a HUD pod one for boost and volts.
  4. #4 Re: gauge recommendations.
    Joliet, IL
    i have aero which reads volts, and have a boost ....
    looks like oil fuel pressure and oil pressure is a must huh.....which of these 5 will i look at least? can the fuel and oil pressure be down in the cubby?
    00 Silvermist GTP
  5. #5 Re: gauge recommendations.
    fuel and wideband can be in the cubby. oil pressure is something you always want to peek at, same with boost and volts.
  6. #6 Re: gauge recommendations.
    Joliet, IL
    prob just gonna get the aeroforce oil pressure add on....65$ that way i cna have 3 gauges....boost, Aero(monitoring oil psi and volts, with indicator lights flashing with KR) and a wideband.....that should be good enough.....
    00 Silvermist GTP
  1. Rotor Recommendations
    By SliceTheRice in forum General Tech Discussion
    Last Post: 04-08-2010, 07:24 PM
  2. used tranny recommendations?
    By jmanrta in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-06-2010, 10:36 PM
  3. Spark Plugs/Gap/Timing recommendations for my 2.7" setup?
    By geforcextreme in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2009, 10:48 PM
  4. brake recommendations
    By jprovinsal in forum Brakes/Suspension/Chassis
    Last Post: 02-18-2009, 08:42 PM
