Thread: 02 Grand Prix Help
Results 1 to 11 of 11
  1. #1 02 Grand Prix Help
    USA
    I just got a 02 Grand Prix GT and when I was driving it home I realized the service engine soon light was on. Then while on the gas I would notice that the car randomly would have the RPMs fluctuate and the car would go back and forth between accelerating and not accelerating even though I was on the gas the whole time. I then also noticed that when I go to start it, the car just cranks for a long time (relative to the other cars I have driven) before starting. Does anyone know what could be causing these?
  2. #2 Re: 02 Grand Prix Help
    honestly, too many variables to point any fingers. i can blindly say you have a vacuum leak, but it wont mean im right. throttle blade sticking or TPS going out? is the MAF clean?
    you have to try a few things out and tell us what happens before we can help any more.
  3. #3 Re: 02 Grand Prix Help
    Apr 2009
    stockton ca
    fuel filter/pump
    crank sensor
    icm/coils
    maf
    but like boy said could be alot of things get the engine light checked
  4. #4 Re: 02 Grand Prix Help
    USA
    Alright thanks guys, I will definitely check out that light, like I should have done earlier.
  5. #5 Re: 02 Grand Prix Help
    Willoughby, Ohio
    fuel pump or throttle position sensor, just to add the the list above for possibilities
  6. #6 Re: 02 Grand Prix Help
    USA
    Thanks guys the codes indicate that the MAF sensor is the problem unfortunately I don't have anything to take it off with
  7. #7 Re: 02 Grand Prix Help
    Apr 2009
    stockton ca
    you can try some maf cleaner spray
  8. #8 Re: 02 Grand Prix Help
    SE Level Member quadracer960's Avatar
    indiana
    mine just went bad too. sometimes it seemed fine, other times i thought it was gonna die on me right then and there. I cleaned my maf sensor, but that did nothing. bit the bullet and spend the $145, but make sure its new and not a refurb one. It takes a t-20 secured torx bit. $10 for a set at autozone. code was prolly a p0102 i take it.
  9. #9 Re: 02 Grand Prix Help
    USA
    I just got the bit/cleaner a little bit ago so Im gonna check it out a little later. Im not sure about the code but the guy told me it was the mass air flow sensor when he pulled the codes
  10. #10 Re: 02 Grand Prix Help
    USA
    I just cleaned the MAF sensor with MAF sensor cleaner. From what I can tell so far the stumbling problem may have been corrected, although when it idles it seems like it jumps around a little bit. Cleaning the MAF sensor seemed to have no effect on the starting issues. Anyone have any ideas about what could be causing the starting issue. The only code was for the MAF sensor
  11. #11 Re: 02 Grand Prix Help
    jumpy idle is going to usually point towards a vacuum leak, but only you would be able to figure that out. other than that i wish you had a scanner so you could tell me what the car is doing.
  1. Grand prix GT side skirts on 97 Grand Prix SE
    By Carnes97SE in forum How To Write-Ups/Tech Tips
    Last Post: 11-17-2013, 05:17 PM
  2. 04+ grand prix
    By JarenSTi in forum Off Topic Discussion
    Last Post: 12-03-2009, 12:51 AM
  3. My 02 Grand Prix GT! vs 98 GTP
    By uNda6gT in forum Track Sessions and Kills
    Last Post: 04-15-2009, 09:48 AM
