Thread: No ABS or Trac
Results 1 to 8 of 8
  1. #1 No ABS or Trac
    Greensboro, NC
    The ABS and Traction Control in my 2000 does not work. The previous owner said he was told a sensor was bad. What should l look at and where are the sensors. Thanks.
    Chuck
  2. #2 Re: No ABS or Trac
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    one of your abs sensors is bad. they are part of the wheel bearing/hub. you will need to put a scanner on the car to find out which one is bad
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  3. #3 Re: No ABS or Trac
    Topeka, KS
    Or take of your wheels and take a look to see if the sensor is broke, hanging, or not plugged in.
    Never hurts to do a visual inspection.
  4. #4 Re: No ABS or Trac
    Dec 2008
    London, Ontario
    this is true
  5. #5 Re: No ABS or Trac
    Manitoba Canada
    most likely a front sensor wire broken in the loop at a front wheel bearing from what I'm told. I had mine break at the front. Easy fix.
  6. #6 Re: No ABS or Trac
    Donating Users alkygto's Avatar
    Nov 2009
    wentzville
    ^This
    1997 Pontiac Grand Prix GTP
    1969 Pontiac GTO
  7. #7 Re: No ABS or Trac
  8. #8 Re: No ABS or Trac
    Greensboro, NC
    I'll check that out, thanks!
  1. yet another abs/trac post
    By myzon26 in forum Brakes/Suspension/Chassis
    Last Post: 02-18-2010, 08:06 AM
  2. Abs/trac off
    By runn141 in forum Brakes/Suspension/Chassis
    Last Post: 02-15-2010, 12:32 AM
  3. my low trac is lit and so is the abs light
    By beast55 in forum General Tech Discussion
    Last Post: 06-27-2009, 01:23 PM
  4. ABS and trac off lights
    By probuilder1 in forum Brakes/Suspension/Chassis
    Last Post: 03-12-2009, 06:31 AM
