I had a blower motor not working and I thought I was going to have to replace it. Turned out to just be a disconnected wire under the dash on the passenger side. I guess where the blower motor is it's pretty easy for a passengers' feet to accidentally disconnect the blower motor wires. You may check there first. As for the headlights, cleaning them helps.....a little. You will be much better off and safer just spending the money now and buying HID headlights. I have heard good things about Spyders and plan on buying a set myself once I have the money. One final point is that you did not mention the miles on the car but you may want to look into getting the transmission fluid changed as that is often neglected and the transmissions are the weak point of these cars.
Good purchase and hope to see you on here posting again.
