Thread: before i re assemble....
Results 1 to 4 of 4
  1. #1 before i re assemble....
    Joliet, IL
    if im never gonna run any smaller than a 3.0-3.2 will a ported stock tb be adequate? or should i open up the inlet on my blower as well since i just did the outlet and run an ls1 tb...
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: before i re assemble....
    Your at no point to upgrade the TB...and if you port your TB, your going to need to re-tune it. As for the port "matching" to the case...just smooth the transition...it should just be the same...but you want to fill the ramp going up on the inlet with epoxy and make it even with the rest of it...sorry if my explanation sucks, but you'll understand what I mean when you get there.
  3. #3 Re: before i re assemble....
    Joliet, IL
    cool thanks alot should i bother porting the tb or no?
    00 Silvermist GTP
  4. #4 Re: before i re assemble....
    Banned - Busted For Scamming
    Feb 2009
    You can if you want, you do realize though you will be hours taking out that much material from the tb if all you have is a dremel.
