Thread: Dome
Results 1 to 5 of 5
  1. #1 Dome
    Feb 2010
    NY
    My Dome Light won't shut off ???
    it came on front and back and it wont shut off, i tried the switch right next to the light switch it did not even affect it ??
    i had to take out the fuse not to drain the battery .
    any ideas or tips or previous experience.
  2. #2 Re: Dome
    Donating Users Warbeaver's Avatar
    St. Louis
    is your dimmer stuck too far to the right? if you go too far over on the dimmer switch, it turns on your dome light.
  3. #3 Re: Dome
    Banned - Busted For Scamming
    Feb 2009
    Wouldnt matter, would time out.
    Im thinking maybe one of your door ajar switches is not working properly.
  4. #4 Re: Dome
    GTX Level Member real diehl's Avatar
    Salina, KS
    Dome
    This is a discussion on Dome within the Tech Tips forums, part of the W Body Tech category
    Haha.
    signature removed for inappropriate content.
    -bio
  5. #5 Re: Dome
    Feb 2010
    NY
    i tried the dimmer it is not stuck, i tried to look for sensors or whatever around the door but i could not find anything i am not sure what triggers those lights to turn off or on ??
    for the time being i took the fuse out but i dont wanna keep it out!!!
  1. Dome/Map lights
    By JCG's-GTP in forum 04+ Specifics
    Last Post: 02-22-2012, 09:11 AM
  2. How do you remove the backseat dome lamp housings?
    By salannelson in forum Audio, Security & Visual Electronics
    Last Post: 07-10-2010, 12:10 AM
  3. map dome light
    By wking2 in forum Audio, Security & Visual Electronics
    Last Post: 03-20-2010, 05:34 PM
  4. removing dome light housing
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 01-16-2010, 06:45 PM
