Thread: Better solution to a gasket?
Results 1 to 5 of 5
  1. #1 Better solution to a gasket?
    SE Level Member corsagtp's Avatar
    Calgary, AB
    Just wondering if anyone has a better solution then a gasket when connecting exhaust pipes together. The flange on the res is leaking where it connects to the downpipe and I know it's the s***y gasket. I know it's not the back of the res because it's got a good clamp and you don't see gas dripping from it like you do where the downpipe connects to the front of the res. The exhaust sounds likes it's ticking when you put some gas on it and is starting to annoy me. Is there something better I can use or where can I get a gasket where it will last and make a good seal?
    Front of resonator and bottom of downpipe
    Back of resonator
    97 GTP - POS parked in backyard
    07 Saab 9-3 2.0 turbo 6-speed - Awesome
  2. #2 Re: Better solution to a gasket?
    in a house
    You could try copper rtv
  3. #3 Re: Better solution to a gasket?
    Calgary, AB
    Maybe I will do that. I threw out the corsa gasket they supplied me with when I put a straight pipe in place of the res but it was just too loud so when I put the res back on I tried using a different gasket a few times and none of them will seal well
  4. #4 Re: Better solution to a gasket?
    Charles City, IA
    Gasket and muffler cement.
    SMGPFC Two Nipple General
  5. #5 Re: Better solution to a gasket?
    Apr 2009
    stockton ca
    you could have it welded but then that limits your ability later on to swap out the exhaust parts easily
  1. 4T65E Hard Shift-Solution
    By jbamonte in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-23-2025, 10:34 PM
  2. Favorite wax/detailing solution
    By katesgrandprix in forum Visual/Body Modifications
    Last Post: 11-24-2009, 10:05 AM
  3. A non welding solution
    By Mad Monkey in forum Off Topic Discussion
    Last Post: 09-23-2009, 02:22 PM
  4. IAT solution
    Last Post: 02-12-2009, 10:11 PM
  5. SS M-90 belt wrap solution!!
    By chico in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-12-2008, 09:38 PM
