Thread: gtp sputtering
Results 1 to 9 of 9
  1. #1 gtp sputtering
    Feb 2010
    NY
    hey, i have a 97 gtp, it runs really well, when i step on it half way enough to get the boost meter to kick on its fine and i love it, however if im going up a steep hill it starts to like choak out or if i put the pedal to the floor it does the same thing only much faster shorter sputs, i was thinking maybe a belt sliping or something, anyone know?
  2. #2 Re: gtp sputtering
    in the infamous words of bio/nick, clogged cat?
  3. #3 Re: gtp sputtering
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    Mine did that when I got it, It was my plug wires. I would put money on it!
  4. #4 Re: gtp sputtering
    Feb 2009
    Red Deer AB
    or maby just bad sparkplugs. But I would slap on a set of wires, and new plugs if you havent already.
  5. #5 Re: gtp sputtering
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    clogged cat or not enough fuel or wires/plugs
  6. #6 Re: gtp sputtering
    to tell you the truth it sounds like an ignition problem. does it only misfire like that under heavy load going uphill or on flat ground too?
  7. #7 Re: gtp sputtering
    Willoughby, Ohio
    ^^^ argreed the sparks not gettting where it needs to be
  8. #8 Re: gtp sputtering
    Feb 2010
    NY
    it does it on flat ground too but only when i put the pedal to the floor, and i need a new ignition switch also bc the computer goes out once in a while, but yeah good call ill get me some new plugs and wires! thanks
  9. #9 Re: gtp sputtering
    Feb 2009
    Red Deer AB
    get ahold of an OBD-II, some part stores will read it for free. thats where I started, it said missfire, so I started with plugs, when I went to change them the sparkplug wire fell apart in my hand, so I "african-american rigged it" back together, went back to the part store and bought new wires. and it was running better just from me fixing up that one wire, so I changed all the plugs and wires, and presto! Good as new.
  1. GTP sputtering, misfireing under load
    By LSXHP in forum General Tech Discussion
    Last Post: 10-23-2012, 04:31 PM
  2. sputtering problem
    By Risinnfallen in forum General Tech Discussion
    Last Post: 01-07-2011, 06:00 PM
  3. sputtering
    By duneking905 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2010, 02:25 AM
  4. Enging sputtering
    By fudhimself in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-19-2009, 07:00 PM
  5. help. car sputtering at wot.
    By 1gtp99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2009, 05:15 PM
