Thread: Car starts runs for 3 sec and dies
Results 1 to 12 of 12
  1. #1 Car starts runs for 3 sec and dies
    SE Level Member rtwilliamson's Avatar
    Gladstone MO
    I am at a loss my car was running fine driving down the road and it died now it will start run for about 3 sec and dies. no codes are showing check engine light is not on. replaced the mass sensor and idle sensor with no luck. it is getting fuel. Any help would be much appreciated.
  2. #2 Re: Car starts runs for 3 sec and dies
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    sounds like a week fuel pump check your fuel pressure
  3. #3 Re: Car starts runs for 3 sec and dies
    Donating Users bigmeadersGTP's Avatar
    illinois
    bypass the fuel pump resistor...
    Its low, its fast, but most of all....its black.
  4. #4 Re: Car starts runs for 3 sec and dies
    Willoughby, Ohio
    ^^^ thats propbably the problem. and if that doesnt work try fuel pressure regulator and crank position sensor
  5. #5 Re: Car starts runs for 3 sec and dies
    Nov 2009
    Grand haven
    ^^^ X3.
  6. #6 Re: Car starts runs for 3 sec and dies
    Gladstone MO
    Thanks to all I By-Passed the resistor and it started and ran fine, going up to get a new one Thank God it is only $10. Again thank you to all for the help.
  7. #7 Re: Car starts runs for 3 sec and dies
    Willoughby, Ohio
    not a problem...now start modding
  8. #8 Re: Car starts runs for 3 sec and dies
    Gladstone MO
    one more quick question, so i bought a new resistor put it on the car and it started doing the same thing. so went back to the old and by-passing. does this mean the fuel pump is getting ready to go? Will it hurt anything long term?
  9. #9 Re: Car starts runs for 3 sec and dies
    west springfield, pa
    i am having the same problem with my gtp. i had a fuel filter fuel pump and regulator put on it and still nothing. im thinkin i should call the garage right now and see if he's tried this bypassing thing..im at a loss and am ready for this issue to be fixed!!
  10. #10 Re: Car starts runs for 3 sec and dies
    finally got my car fixed!! it ended up being the ECM
  11. #11 Re: Car starts runs for 3 sec and dies
    GT Level Member jdmgtp's Avatar
    MI
    please help my car is doing the same thing how do I bypass the resistor?
  12. #12 Re: Car starts runs for 3 sec and dies
    MI
    nevermind the resistor by-pass fixed it.
  1. Starts then Dies!
    By 1999GTP1999 in forum General Tech Discussion
    Last Post: 01-29-2010, 08:42 AM
  2. Need some help folks, car starts, runs, then dies
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2010, 05:48 AM
  3. 04 starts then dies
    By oldtruckluvr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-06-2009, 08:09 PM
  4. HELP: Starts then dies after LIM
    By rfmgtp02 in forum General Tech Discussion
    Last Post: 06-23-2009, 03:35 PM
  5. car starts, runs for a second, then dies
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2009, 11:34 AM
