Thread: Ignition Switch Replacement?
Results 1 to 10 of 10
02BlueGT Ignition Switch Replacement? 04-05-2008, 12:26 AM
SyntheticShield Re: Ignition Switch... 04-05-2008, 10:51 AM
02BlueGT Re: Ignition Switch... 04-05-2008, 11:07 AM
SyntheticShield Re: Ignition Switch... 04-05-2008, 01:02 PM
02BlueGT Re: Ignition Switch... 04-05-2008, 03:14 PM
02BlueGT Re: Ignition Switch... 04-05-2008, 03:32 PM
SyntheticShield Re: Ignition Switch... 04-05-2008, 05:48 PM
Toasty Re: Ignition Switch... 04-05-2008, 10:46 PM
SyntheticShield Re: Ignition Switch... 04-05-2008, 11:23 PM
1998gpgt Re: Ignition Switch... 04-06-2008, 08:59 PM
  1. #1 Ignition Switch Replacement?
    Hoffman/Schaumburg, IL
    Does anyone have a write-up to replace the ignition switch, cause I need to do this, and cant find a write-up anywhere... thanks for any responses
  2. #2 Re: Ignition Switch Replacement?
    Oklahoma
    Moved this over to the tech lounge. You might click on the How To link at the top and see if we have one in there or not, Im not sure if we do or do not. I know there is one out there somewhere because its what I used when I did mine.
  3. #3 Re: Ignition Switch Replacement?
    I know I've seen one, but there was only the ignition relay mod in our How to Section
  4. #4 Re: Ignition Switch Replacement?
    Oklahoma
    Okay, if you dont find it, I'll try and get what I have posted up. It is not my How To, I did not make it up and Im not sure who the credit goes to. You might check the other site because I got it off there.
    I dont mind posting it up here, I just would feel better if the original author knew about it.
  5. #5 Re: Ignition Switch Replacement?
    ^^^ understandable, I found it, and you've got a PM
  6. #6 Re: Ignition Switch Replacement?
    Also, would Dielectric grease help prevent the arching that causes the carbon build-up?
  7. #7 Re: Ignition Switch Replacement?
    Oklahoma
    Quote Originally Posted by 02BlueGT View Post
    I dont know that I would use Dielectric grease. However, BackInBlack has an ignition saver modification that should do the trick. Im not sure where its at on here, there was a thread about it. But I used it when I put in my new switch/harness.
  8. #8 Re: Ignition Switch Replacement?
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    i wouldnt take apart a good ignition switch... too many tiny parts that may not go back together right
    i'd use either backinblack's ignition saver mod (or my plug and play version of same)
  9. #9 Re: Ignition Switch Replacement?
    Oklahoma
    Toasty, forgive me, but I forgot you had done a version of that. I should have remembered since it was plug and play.
  10. #10 Re: Ignition Switch Replacement?
    SE Level Member 1998gpgt's Avatar
    McHenry, IL
    Heres the one i used. Everything is pretty much straight forward but its always nice to have some kind of reference. ClubGP Message Forum troubleshooting
    1998 Grand Prix GT 337whp/363wtq 12.952 @ 112.02
    2000 Grand Prix GT & 2007 Grand Prix GT
    2004 GTO 13.610 @ 102.69
    1985 Cutlass 455/TH350
  1. Repair Your Power Windows Switch[*]
    By J_Ferguson in forum How To Write-Ups/Tech Tips
    Last Post: 10-19-2013, 01:07 AM
  2. window switch trim
    By kingd44 in forum The Rant Forum
    Last Post: 03-23-2008, 08:38 PM
  3. Need More Help, Ignition
    By SyntheticShield in forum General Tech Discussion
    Last Post: 01-28-2008, 12:17 AM
  4. Relocate HUD switch [*]
    By Toasty in forum How To Write-Ups/Tech Tips
    Last Post: 01-27-2008, 07:03 PM
