Thread: Ignition Switch Replacement?
Results 1 to 10 of 10
  1. #1 Re: Ignition Switch Replacement?
    Oklahoma
    Okay, if you dont find it, I'll try and get what I have posted up. It is not my How To, I did not make it up and Im not sure who the credit goes to. You might check the other site because I got it off there.
    I dont mind posting it up here, I just would feel better if the original author knew about it.
  2. #2 Re: Ignition Switch Replacement?
    Hoffman/Schaumburg, IL
    ^^^ understandable, I found it, and you've got a PM
  3. #3 Re: Ignition Switch Replacement?
    Also, would Dielectric grease help prevent the arching that causes the carbon build-up?
  4. #4 Re: Ignition Switch Replacement?
    Oklahoma
    Quote Originally Posted by 02BlueGT View Post
    I dont know that I would use Dielectric grease. However, BackInBlack has an ignition saver modification that should do the trick. Im not sure where its at on here, there was a thread about it. But I used it when I put in my new switch/harness.
  5. #5 Re: Ignition Switch Replacement?
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    i wouldnt take apart a good ignition switch... too many tiny parts that may not go back together right
    i'd use either backinblack's ignition saver mod (or my plug and play version of same)
  1. Repair Your Power Windows Switch[*]
    By J_Ferguson in forum How To Write-Ups/Tech Tips
    Last Post: 10-19-2013, 01:07 AM
  2. window switch trim
    By kingd44 in forum The Rant Forum
    Last Post: 03-23-2008, 08:38 PM
  3. Need More Help, Ignition
    By SyntheticShield in forum General Tech Discussion
    Last Post: 01-28-2008, 12:17 AM
  4. Relocate HUD switch [*]
    By Toasty in forum How To Write-Ups/Tech Tips
    Last Post: 01-27-2008, 07:03 PM
