Thread: zzp dp
Results 1 to 10 of 10
  1. #1 zzp dp
    Feb 2010
    St. Louis
    zzp told me i wanted a 2.5" dp with cat for my n/a 06 gp. is that true or do i still wanna go with the 3" with cat?
  2. #2 Re: zzp dp
    Willoughby, Ohio
    i put a 3'' on my n/a GT, i fgured if im paying for a dp im goin 3''
    here is a thread i started when i was lookin for a dp...
    http://www.grandprixforums.net/f17/e...tup-19162.html
  3. #3 Re: zzp dp
  4. #4 Re: zzp dp
    Willoughby, Ohio
    ^^ haha thats what you told me and i bought the 3'' dp!!
  5. #5 Re: zzp dp
    Feb 2010
    St. Louis
    so i want the 3" catted and i would only need one step down from the dp to the resonator right? or do i need one from the dp to the manifolds as well?
  6. #6 Re: zzp dp
    Feb 2010
    St. Louis
    Quote Originally Posted by 06grandprix93 View Post
    on zzp, this is what is says, so would i even need a step down?
    Bolt in with cat downpipes can be used on stock to highly modified cars. They do not require PCM programming and are emissions legal. We use Magnaflow, high flowing catalytic converters. They should not void your factory warranty. They bolt into a stock or aftermarket cat back exhaust system. They include an O2 bung for the rear factory O2 sensor. All bolt in downpipes have a 2.5" exit flange that bolts in the factory location, if you would like a 3" exit flange please attach a $20 custom payment to your downpipe order and we will include the correct bolt in flange.
  7. #7 Re: zzp dp
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    the dp will bolt to your manifold. you will need a reducer pipe from the dp outlet to the stock catback
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  8. #8 Re: zzp dp
    Feb 2010
    St. Louis
    Quote Originally Posted by Rather B Blown View Post
    im getting the catted dp. u mean the resonator?
  9. #9 Re: zzp dp
    Feb 2010
    St. Louis
    also i can weld, so what would be the cheapest between the 3" weld-in w/ cat and the 3" bolt-in with cat? cheapest with the necessary O2 bungs/extensions?
    thanks
  10. #10 Re: zzp dp
    Charles City, IA
    Get the bolt in one. It will be easier to take out when you want to top swap and get headers.
    SMGPFC Two Nipple General
