Thread: swishing noise in dash
Results 1 to 5 of 5
  1. #1 swishing noise in dash
    SE Level Member dwolf's Avatar
    Feb 2010
    arkansas
    there is a swishing noise that has started in my dash after letting the car set up several months.at 1st i thought it was wiper motor,during ice storm the wiper arms were stripped where they wont fit right onto the post so they've ben removed therefore its possiable for wipers to be on and not realize it being there are no wiper arms or blades.i said all that to let you no what the sound is like accept its in the dash. it does it wheather the heat,air is on or off,has dual climate control.could it be the vacuum to the heat/air controls? everything seems to work proper other than this swishing noise,sounds like something trying to open or close,i'm stumped.
  2. #2 Re: swishing noise in dash
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    sounds like you have air in ur cooling system try bleeding it, your heater core is probaby parshally blocked not causing it to circulate properly u can alway use a garden hose and flush it by pulling the lines off and spraying the hose threw both heater lines,
  3. #3 Re: swishing noise in dash
    MO
    air bubble in your heater core. if you aren't getting coolant inside your car (do you smell antifreeze?) then it's not a huge deal.
    <brandonl2000> LMAO D!!
  4. #4 Re: swishing noise in dash
    Feb 2010
    arkansas
    thanks,never even thought it would be air in heater core. car runs cool,no smell,floor dry.guess i'll let it ride 4 now.
  5. #5 Re: swishing noise in dash
    GET MOAR COOLANT.
    and bleed the system.
    Hot spots = bad for your engine.
  1. Weird howling noise under dash?
    By hjz8785 in forum General Tech Discussion
    Last Post: 07-25-2011, 10:29 PM
  2. High pitched noise coming from dash?
    By Gortox454 in forum General Tech Discussion
    Last Post: 08-14-2010, 08:48 AM
  3. GTP Dash Help
    By NESHO in forum General Tech Discussion
    Last Post: 02-20-2009, 09:26 PM
  4. new dash
    By oneswt00gtp in forum Visual/Body Modifications
    Last Post: 04-03-2008, 03:41 PM
