Thread: Cigerette Lighter Not working
Results 1 to 5 of 5
  1. #1 Cigerette Lighter Not working
    Maryville, TN
    Alright everyone, I feel like this is going to be a stupid question set, but I couldn't find anything about it in any of the other threads or in the search engine.
    I have a 07 Base Grand Prix and currently neither one of the cigarette ports are working. Where/what should I look at to troubleshoot this? Or is this a common problem with a quick fix?
    Thanks in advance!!
  2. #2 Re: Cigerette Lighter Not working
    GTX Level Member bronzemist02's Avatar
    Canada
    Check the fuse for it. It could be blown. Check your owners manual, it will say exactly where the fuse is.
  3. #3 Re: Cigerette Lighter Not working
    Donating Users ls6velless454's Avatar
    Nov 2009
    Portage, IN
    Should be located in the driver side dash compartment when you open your door. Take your finger nail under the slit part of it and pop the panel off, and look for the 10 or 15 that is blown that should fix your problem GL
    There is no replacement for displacement........unless you have a supercharger or turbo
    2000 Bright Red GTP Coupe GXP axle back, GMPP sway bar, NGK TR6, 180 stat. (Uninstalled Aeroforce Interceptor, DHP PCM, FWI, Gen V on the way) and still no pulley in sight.
  4. #4 Re: Cigerette Lighter Not working
    SE Level Member Martin 04's Avatar
    Oct 2008
    queens
    i have an 04 and the ports are only for chargers they were not made for cigarette lighters, i'm not sure if its the same on your model though
  5. #5 Re: Cigerette Lighter Not working
    there are no cigarette lighters in our cars unless you have one in an ash tray, which i dont know if 04+ cars have.
  1. Cig lighter doesn't work! Please help.
    By jimintheb0x in forum General Tech Discussion
    Last Post: 07-26-2010, 01:00 AM
  2. Cigarette Lighter Problems
    By missyfisch in forum Audio, Security & Visual Electronics
    Last Post: 10-08-2009, 09:39 AM
  3. cig lighter
    By MizzBecca in forum General Tech Discussion
    Last Post: 07-12-2009, 11:08 PM
  4. Removing ash tray/rearranging cigarette lighter?
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 04-17-2008, 05:32 AM
  5. lighter coil pack bracket?
    By s1795so2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2008, 08:29 PM
