Thread: Fog Light Switch-On light
Results 1 to 5 of 5
  1. #1 Re: Fog Light Switch-On light
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    Here's a writeup on replacing the bulb with LEDs (from the resident GP electrical god):
    Fog lamp switch LEDs
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  2. #2 Re: Fog Light Switch-On light
    New York
    Thanx. How doyou take the switch out of the dash?
  3. #3 Re: Fog Light Switch-On light
    GTP Level Member SuperSport's Avatar
    Michigan
    Remove the two screws under the steering column and pull out the bottom trim. Then start popping off the dash bezel from the bottom. Pull the bezel slowly away from the dash and unplug the switch. Then unsnap the switch from the back of the bezel.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  4. #4 Re: Fog Light Switch-On light
    New York
    Thanx. That is what I was loooking for!
  1. 2004+ Rear Seat Interior Light Switch Broken anyone find this part?
    By UCF04GPGTPCompG in forum Visual/Body Modifications
    Last Post: 02-27-2010, 01:39 PM
  2. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  3. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
  4. Need Instructions on signal light switch replacement
    By ragtops in forum General Tech Discussion
    Last Post: 03-22-2009, 05:44 PM
  5. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
