Thread: Help. I cant get very much heat.
Results 1 to 20 of 23
  1. #1 Help. I cant get very much heat.
    Donating Users squeaks130's Avatar
    Fargo, ND
    First of all I live in ND. And its fifteen below right now. And I have almost no heat in my 00 gt, this sucks severely. Here is what is going on, I turn the fan to high and it blows a little air but not hot or a lot of flow. I turn it to cold and I get much more. I have replaced the Thermostat, (and bleed the system), blower motor, and the resistor pack. Whats left? Cause its getting real old having to where overalls on long trips. any help would be appreciated. btw I just got the car a month ago, so I don't know how long this has been going on.
  2. #2 Re: Help. I cant get very much heat.
    Nov 2008
    norman oklahoma
    heater core either needs flushed or replaced
  3. #3 Re: Help. I cant get very much heat.
    Charles City, IA
    Check and see if you have a cabin air filter. Or if the duct to the blower motor is plugged up.
    SMGPFC Two Nipple General
  4. #4 Re: Help. I cant get very much heat.
    Fargo, ND
    I dont think that the heater core is plugged, because both pipes going into it are warm... where is that door and cabin air filter?
  5. #5 Re: Help. I cant get very much heat.
    PA
    Quote Originally Posted by squeaks130 View Post
    The heater core could be plugged up so that not much air is going through. This would also explain why you get more air blowing out when you turn it to cold.
    2001 GSE
  6. #6 Re: Help. I cant get very much heat.
    Fargo, ND
    So when u talk about the heater core being plugged are talking about the coolant part or the part that the air goes through?
  7. #7 Re: Help. I cant get very much heat.
    Nov 2008
    norman oklahoma
    where your heater hoses are going into firewall unhook both take a water hose and flush both ways also you will see if its plugged
  8. #8 Re: Help. I cant get very much heat.
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    first off is the heat hotter wen its on the lowest speed ? wen you turn the speed up all the way does the heat go from warm to cold??
  9. #9 Re: Help. I cant get very much heat.
    Fargo, ND
    Quote Originally Posted by imdaman3 View Post
    I am not sure, all I know is that I am not getting enough heat, and I have pretty much left it on high. but tomorrow I will take the car for a spin and see what it does.
  10. #10 Re: Help. I cant get very much heat.
    Feb 2010
    ohio
    ok,
  11. #11 Re: Help. I cant get very much heat.
    Fargo, ND
    Alright I sat and fiddledicked with it today. And here is what I found: turning the fan speed up and down does not seem to have any effect on temperature, but turning the temp knob from hot to cold causes the amount of air coming out the vents to almost double in speed. So does this help anyone with ideas on whats wrong?
  12. #12 Re: Help. I cant get very much heat.
    Charles City, IA
    The fins are clogged up on your heater core not allowing air to flow threw.
  13. #13 Re: Help. I cant get very much heat.
    Fargo, ND
    Alright.. my next important question. how do I get to the heater core?? and would i want to replace or just clean out?
  14. #14 Re: Help. I cant get very much heat.
    Feb 2010
    ohio
    flushin it will be easiest and there are to lines that go into the alternator bracket u pull them off and spray water threw each one unto it flow fast
  15. #15 Re: Help. I cant get very much heat.
    Fargo, ND
    I haven't flushed my heater core yet.... (its been warm out so I haven't needed the heater much) but i got another problem which i am not sure if its related or not. yesterday i went to the car wash and when the washer passed over the cowl I suddely had a river on my passenger side floor. Is this a related problem or something totally different?
  16. #16 Re: Help. I cant get very much heat.
    Charles City, IA
    go to the how to section and the water in the floor board fix will take care of it.
  17. #17 Re: Help. I cant get very much heat.
    GT Level Member skidoojames151's Avatar
    seattle
    ok, so the AIRFLOW is being blocked in his case because he mentioned that on cold it moves way more air, so flushing the inside of the core wont do anything for his issue, that would fix the issue of it not ever getting warm, more than likely there is crap on the fins of the core that need to be cleaned and the flow will return to normal.
  18. #18 Re: Help. I cant get very much heat.
    Fargo, ND
    Thats kinda what I was thinking. How hard is to clean out the fins on the core?
  19. #19 Re: Help. I cant get very much heat.
    seattle
    ive been considering cleaning mine as well and what i was going to do is take the core out and inspect it and then pressure wash it
  20. #20 Re: Help. I cant get very much heat.
    seattle
  1. Heat???
    By newmarket23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-23-2009, 12:44 AM
  2. No Heat!
    By srspicer in forum General Tech Discussion
    Last Post: 10-25-2009, 11:55 PM
  3. Heat and A/C??
    By lorenzojay in forum General Tech Discussion
    Last Post: 09-28-2009, 08:43 PM
  4. How much does heat......
    By GTP4 in forum PCM Tuning
    Last Post: 05-08-2009, 11:54 AM
  5. No heat -- or very little
    By Teancum in forum General Tech Discussion
    Last Post: 03-27-2009, 07:55 AM
