Thread: 99 GTP WIERD problem...need HELP ASAP!!
Results 1 to 11 of 11
  1. #1 99 GTP WIERD problem...need HELP ASAP!!
    SE Level Member LSXHP's Avatar
    Morris IL
    Ok so I posted this in the electrical section but figure this is probably a better spot for it...
    Ok so im going through the car wash last night and my climate control starts counting up from the 33 it was outside all the way to like 86 or something, then the lights start flickering on the unit. I turn the headlights off and it gets brighter like its supposed to but dont flicker, then all the sudden ALL my dash lights shut off as if I shut the lights off, DIC and everything else got bright, so I turn the lights back on. Then I notice the fog lights wont turn on. Had to be somewhere so I figure ill look at it today, hr later get pulled over because my tail lights arent working!!!! They light up when I use a turn signal or brake but not just when the lights are on....then I get where im going and I shut the car off, open the door and the chime is ringing all quick like I left the lights on but there off!! is going on with this thing?!?!?
    oh also my DIC has been flashing all 0.0 for some time now as soon as the car moves st starts doing that and the TC is always off, I cant turn it back on....This car is really pissing me off....kinda wishing I never got that valvecover recall done...
    White 99 GTP-180*,FWI,ZZP Plog,3"DP.ZZP PCM, Magnaflow resinator.
    SOLD June 2009 Silver 2000 Z-28 383LSX Stroker, 10.94@122 N/A
    2004 Suzuki GSXR-750, lowered, Piped,filters,smoked screen
  2. #2 Re: 99 GTP WIERD problem...need HELP ASAP!!
    Nov 2009
    Grand haven
    PCM, Battery, alt?
  3. #3 Re: 99 GTP WIERD problem...need HELP ASAP!!
    Morris IL
    not battery or alt, all good battery is a yr old and car only has 72k on it.
  4. #4 Re: 99 GTP WIERD problem...need HELP ASAP!!
    Charles City, IA
    I would go with the ignition switch.
    SMGPFC Two Nipple General
  5. #5 Re: 99 GTP WIERD problem...need HELP ASAP!!
    Morris IL
    nah ignition wouldnt have anything to do with it...
  6. #6 Re: 99 GTP WIERD problem...need HELP ASAP!!
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    try unhooking the battery over night, let the computer reset, have you checked all the fuses, even the ones under the hood?
  7. #7 Re: 99 GTP WIERD problem...need HELP ASAP!!
    Morris IL
    Quote Originally Posted by 98GTPCALGARY View Post
    Im goning to do that tomorrow.
  8. #8 Re: 99 GTP WIERD problem...need HELP ASAP!!
    Feb 2009
    Red Deer AB
    Any luck?
  9. #9 Re: 99 GTP WIERD problem...need HELP ASAP!!
    Morris IL
    Well got my lights fixed...turns out it was a fuse, go figure. Never seen a blown fuse cause so many problems at once, but im glad and suprised, nothing ever is simple for vehicle repairs for mme lol it always ends up being something major and expensive. Also took the DIC out and took it apart, everything looks good but it still dont work, just flash's all 0.0's. Also noticed once I turn the key to the run position its about 9 seconds until it begins to flash, unless I start the car and move it then it begins as soon as I move the car.
  10. #10 Re: 99 GTP WIERD problem...need HELP ASAP!!
    Quote Originally Posted by schroedes View Post
    its called, old piece of ****
    It's called your vagina is full of sand and pus
  11. #11 Re: 99 GTP WIERD problem...need HELP ASAP!!
    Morris IL
    maybe....but from what ive seen laltely you have nothing usefull to say so, get off my thread keyboard commando.
  1. Wierd Sound
    By TeeWX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2010, 02:22 PM
  2. WIERD!!! has this happened to anyone else?
    By aron2409 in forum General Tech Discussion
    Last Post: 11-25-2009, 01:34 AM
  3. Electrical Problem!! need help asap
    By gp3800t in forum General Tech Discussion
    Last Post: 10-19-2009, 04:58 PM
  4. Please Read ASAP, Need all ur input asap
    By SteelCityTA in forum Off Topic Discussion
    Last Post: 03-29-2009, 02:41 AM
  5. kr wierd issue
    By GTP4 in forum PCM Tuning
    Last Post: 02-18-2009, 08:20 AM
