Thread: installing remote start
Results 1 to 6 of 6
  1. #1 installing remote start
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    hello all, just wondering if anyone has ever done this themselves? i understand you wont be able to help me with my particular starter, but i was wondering how hard it is to get to all the needed wires in the car??
    any advice/tips will be most appreciated! thanks in advance
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  2. #2 Re: installing remote start
    GTP Level Member Scimmia's Avatar
    QCA, IA
    I've done it. It's not too bad if you're good with a meter and know when and how to use diodes, relays, etc. Most of the wires can be had at the ignition harness or at the BCM.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: installing remote start
    Nov 2008
    Fremont Nebraska
    this remote start system i have says it works with Passkey, Passlock, and Passlock II security systems. mine has passkey III, will this still work?
  4. #4 Re: installing remote start
    QCA, IA
    You need a bypass module for PK3. It won't work as-is. What starter is this?
  5. #5 Re: installing remote start
    Nov 2008
    Fremont Nebraska
    it is the bulldog security rs82b. it has a little box i put a programmed spare key in....
  6. #6 Re: installing remote start
    QCA, IA
    If you've got the extra box to put the spare key in, you should be fine.
  1. Remote Start
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-26-2009, 01:00 PM
  2. do I have a remote start or what??
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-24-2009, 02:28 PM
  3. Remote start
    By putskijr in forum Audio, Security & Visual Electronics
    Last Post: 11-23-2009, 08:33 AM
  4. Remote start on GP
    By Freebeer187 in forum General Tech Discussion
    Last Post: 04-12-2009, 07:30 PM
