I had the same issue replaced the sensor, still had the problem icm was the faulty part but it is a difficult call between the two. However icm is much easier to replace
i checked ICM last fall, My car did a wierd thing it made the shudder feeling and tach went to 0 and stalled and then started back up and ran ok does it sound like the crank shaft position sensor to you guys
More often than not, the cause for the tach dropping to 0 and then stalling is the crank sensor.
I agree with fingures BUT I had my ICm go out after I replaced it in less than 6 months (so much for duralast)
Autozone/Advance Auto/non OEM ignition components (ex. Crank/cam sensors, icms). = I highly advise against. Just from past experience.. Not saying they are all bad but have a much higher failure rate/incorrect specifications. Just a heads up.
Sent using my Galaxy SIII on Tapatalk 2
Yep I know but was in a hurry only reason I used duralast both times is second time It ws covered under warrenty it happens again I go with MSD
