Thread: Need help with with rear strut mount??
Results 1 to 7 of 7
  1. #1 Need help with with rear strut mount??
    Feb 2009
    BrownsTown, MI
    I was looking for a car for a friend i found one and this was the only problem "The problem is the strut on the back right rusted through the trunk." is there a fix for this she is not going to get the car but i went outside to see mine and it has a little bit of rust is there not much... anything i can do before it rusted through???(Michigan weather) Thanks
    Does anybody here has this happen to there car??
  2. #2 Re: Need help with with rear strut mount??
    Feb 2009
    BrownsTown, MI
  3. #3 Re: Need help with with rear strut mount??
    GT Level Member putskijr's Avatar
    Waterloo, Iowa
    its on most gps. idk what to do to fix it tho
    180* tstat, homemade FWI, autolite 605's, tuned by FoSho99, clear corners, 6000k hids, painted interior, and sum more
  4. #4 Re: Need help with with rear strut mount??
    GTX Level Member Deimos's Avatar
    iowa
    POR15 does wonders. If you are keeping your car use that paint.
  5. #5 Re: Need help with with rear strut mount??
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    sand it down or wire wheel it, paint it or por15, then undercoat it i had many of these cars the rubber under coating helps a bunch cus when the strut towers get wet the water runs rite off, i do it to cars with no rust to prevent rust and yrs later still no rust
  6. #6 Re: Need help with with rear strut mount??
    Feb 2009
    BrownsTown, MI
    Ok so i found the pro15 am going to order it online thanks for the info any other ideas let me know thanks
  7. #7 Re: Need help with with rear strut mount??
    Nov 2009
    Grand haven
    Get rid of it while you can and buy one from down south.
  1. Strut Mount Caps?
    By Silver GTP in forum Brakes/Suspension/Chassis
    Last Post: 01-09-2010, 11:50 PM
  2. missing spacer on rear strut mount '06 GXP
    By tta1401 in forum General Tech Discussion
    Last Post: 07-25-2009, 05:19 PM
  3. Strut Bolts Stuck on Rear Knuckle
    By VerticalMK in forum Brakes/Suspension/Chassis
    Last Post: 06-13-2009, 11:34 PM
  4. Front Strut Mount from Advance Auto Parts
    By Abrasive in forum Shops and Community Heroes
    Last Post: 04-02-2009, 11:53 AM
  5. 98 NAPA Front Strut Tower Mount
    By Lion29GTP in forum Brakes/Suspension/Chassis
    Last Post: 03-10-2009, 02:10 AM
