Thread: Hood Pin switch location?
Results 1 to 3 of 3
  1. #1 Hood Pin switch location?
    SE Level Member cboth686's Avatar
    Oct 2008
    Canada
    Hello all,
    I recently had my car serviced, and now my aftermarket remote starter isn't working. I've read that it could be due to the hood pin switch, or the tailights? Where is this "hood pin switch?"
    When I attempt to start the car, the signal lights flash repeatedly, so it's not the remote or reciever. Problem is, after this flashing the engine doesn't kick in to start.
    This is a problem cause I lost my chipped key, but I was able to fool the security by remote starting the car, and then putting in the cut-key (it's from Canadian Tire).
    Any help would be greatly appreciated. I have the feeling it's a matter or loose wires or something.
  2. #2 Re: Hood Pin switch location?
    Donating Users nvsridez's Avatar
    sw WI
    Hello.
    I had a remote start on my Gtp. It did not come with a "hood pin" style hood sensor. It actually had a plastic piece, about 1" x 3/8" that was stuck to the hood, and when the hood was down, it detected it somehow. When I installed my SD hood, i didn't know what this "sensor" was for, so i let it hang in the engine bay...Well, my remote start quit working after i did that...I had to locate this sensor, and i mounted it to the firewall in the "hood closed" position. I would like by your driver front strut mount area, for a small plastic piece with 1 wire leading to it...Good luck.
  3. #3 Re: Hood Pin switch location?
    SE Level Member GTPcoupe's Avatar
    Feb 2010
    Canada
    My red GP has remote start (even though I don't drive it in winter lol) and it does not have any hood pin switch. The only time it has not started and the lights flashed like you described, was when the switch under my dash for the remote start was turned off. My foot must have hit it or something and that's all it was. So see if you have a on/off switch somewhere.
    '99 GTP coupe - Growing mod list/summer car
    '98 GTP Sedan - Winter ride, 315,000+kms and going strong!
  1. Converting stock hood to "40th Anniversary" hood w/heat extractors[*]
    By Quicksilver_GP in forum How To Write-Ups/Tech Tips
    Last Post: 08-28-2013, 09:12 PM
  2. Cooling Fan Switch location?
    By shaner in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-22-2012, 10:15 AM
  3. Location of HUD switch on dash...
    By BlownBigBlock in forum Audio, Security & Visual Electronics
    Last Post: 09-23-2009, 12:40 PM
  4. Location of ECM
    By TOMB in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-17-2009, 01:26 AM
  5. GTP PCM location
    By razoredge in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-16-2008, 07:36 PM
