Thread: LOW COOLANT light flickers?
Results 1 to 9 of 9
  1. #1 LOW COOLANT light flickers?
    Donating Users kind153's Avatar
    Pittsburg, KS
    Hi all,
    it's 98 GT, and it has a LOW COOLANT light on most of the time due to bad sensor. It's been going on and off, but usually it stays on.
    (edit: it stays on at its maximum bright)
    Recently, it's started to flicker when driving. (I was driving when it happened, went away(stay bright) in a few minutes)
    to describe it in more detail, it doesn't completely go off while flickering, it goes to "dimmed" like other interior lights when light's on.
    but I know the cluster lights doesn't go dim when lights on.
    Is the bulb going out or what?
    it came back to normal (bright) today, by the way.
    Thanks!
  2. #2 Re: LOW COOLANT light flickers?
    Charles City, IA
    Just unplug the sensor.
    SMGPFC Two Nipple General
  3. #3 Re: LOW COOLANT light flickers?
    Pittsburg, KS
    Yeah but I want to know why the light flickers.
  4. #4 Re: LOW COOLANT light flickers?
    Charles City, IA
    Could be going out. If you unplug the sensor the light will never come on again and you will not have to worry about it.
  5. #5 Re: LOW COOLANT light flickers?
    PA
    Or you could change the sensor.
    The sensors are known to go bad. But also, the hole can sometimes clog up and cause bad readings. If you are going to fix it, buy the new sensor, drain some coolant out, remove the old sensor, and check the hole. If the hole is gunked up, clean it out and install the old sensor and see if it works. If it does, return the new one.
    2001 GSE
  6. #6 Re: LOW COOLANT light flickers?
    Donating Users alkygto's Avatar
    Nov 2009
    wentzville
    ^Good info, right on, I just replaced mine, dealer part, I paid around $45 I think.
    1997 Pontiac Grand Prix GTP
    1969 Pontiac GTO
  7. #7 Re: LOW COOLANT light flickers?
    Guam
    Quote Originally Posted by kind153 View Post
    Hi all,
    You answered your own question...
  8. #8 Re: LOW COOLANT light flickers?
    Guam
    Hi all,
    You answered your own question as to why the light flickers...
  9. #9 Re: LOW COOLANT light flickers?
    Pittsburg, KS
    Quote Originally Posted by toolguy View Post
    Please elaborate. It is my understanding that the sensor only gives 1 or 0 (or PCM decides 1 or 0 according to sensor's reading).
    Unless the sensor brightness is designed to indicate how low the level is, I don't think there is any reason for it to flicker.
  1. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  2. Low coolant light?
    By BwolfGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-03-2009, 01:13 PM
  3. Low Coolant Light
    By Helios in forum General Tech Discussion
    Last Post: 02-19-2009, 04:13 PM
  4. Low Coolant Light
    By Scott B in forum General Tech Discussion
    Last Post: 12-05-2008, 05:21 AM
  5. Oil Light Flickers in Cold Weather
    By kingbrentdwyer in forum General Tech Discussion
    Last Post: 10-30-2008, 07:12 AM
