Thread: LOW COOLANT light flickers?
Results 1 to 9 of 9
  1. #1 Re: LOW COOLANT light flickers?
    Charles City, IA
    Just unplug the sensor.
    SMGPFC Two Nipple General
  2. #2 Re: LOW COOLANT light flickers?
    PA
    Or you could change the sensor.
    The sensors are known to go bad. But also, the hole can sometimes clog up and cause bad readings. If you are going to fix it, buy the new sensor, drain some coolant out, remove the old sensor, and check the hole. If the hole is gunked up, clean it out and install the old sensor and see if it works. If it does, return the new one.
    2001 GSE
  3. #3 Re: LOW COOLANT light flickers?
    Donating Users alkygto's Avatar
    Nov 2009
    wentzville
    ^Good info, right on, I just replaced mine, dealer part, I paid around $45 I think.
    1997 Pontiac Grand Prix GTP
    1969 Pontiac GTO
  1. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  2. Low coolant light?
    By BwolfGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-03-2009, 01:13 PM
  3. Low Coolant Light
    By Helios in forum General Tech Discussion
    Last Post: 02-19-2009, 04:13 PM
  4. Low Coolant Light
    By Scott B in forum General Tech Discussion
    Last Post: 12-05-2008, 05:21 AM
  5. Oil Light Flickers in Cold Weather
    By kingbrentdwyer in forum General Tech Discussion
    Last Post: 10-30-2008, 07:12 AM
