Thread: Weird temp gage problem
Results 1 to 5 of 5
  1. #1 Weird temp gage problem
    Mesa, Arizona
    Okay 1994 SE 3.1
    The needle on the temp gage suddenly pegs to the red, overheat mark. I stop the car and the engine is a very normal temp...no overheating. I continue driving, the temp goes down to the normal range swiftly.
    Now, I notice that when I am running the heater and when the needle begins to peg to the red overheat mark the heater stops blowing warm air and begins to blow cold. A few moments later the heater starts blowing warm air again and at that exact moment the needle begins dropping into the normal range. This occurs several times as I am driving around.
    I can't see any other indication or symptom of anything else going on with the engine. Not using water, oil level okay, etc.
    This seems very weird to me.
  2. #2 Re: Weird temp gage problem
    Mesa, Arizona
    bump
    Anyone?
  3. #3 Re: Weird temp gage problem
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    sounds like low coolant. or an air bubble in there if youve recently had the cooling system messed with
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  4. #4 Re: Weird temp gage problem
    Guam
    Have you checked the coolant levels in the overflow bottle and the radiator itself?
    Sounds like you have air in the system, or it is sucking air in from a leak.
  5. #5 Re: Weird temp gage problem
    Mesa, Arizona
    Thanks for the replies. Yes, I have heard that it may be some kind of air in the sytem. It has used a little bit of coolant and when level it off the problem goes away.
    Where could air be being sucked into the coolant system?
  1. Weird problem when trying to start
    By JbrownGTP in forum General Tech Discussion
    Last Post: 12-29-2009, 09:18 PM
  2. Really weird problem!
    By pyccke87 in forum General Tech Discussion
    Last Post: 10-03-2009, 10:22 PM
  3. weird problem???
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-26-2009, 12:44 PM
  4. Weird noise problem!
    By GTP4 in forum Audio, Security & Visual Electronics
    Last Post: 04-22-2009, 11:41 AM
  5. Weird tranny problem
    By 04CompG in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-03-2008, 07:51 AM
