Thread: headlights bounce around
Results 1 to 20 of 21
fremmy182 headlights bounce around 02-19-2011, 11:01 PM
machinegunsquid Re: headlights bounce around 02-19-2011, 11:04 PM
fremmy182 Re: headlights bounce around 02-19-2011, 11:06 PM
PurpleGuy Re: headlights bounce around 02-19-2011, 11:07 PM
machinegunsquid Re: headlights bounce around 02-19-2011, 11:08 PM
fremmy182 Re: headlights bounce around 02-19-2011, 11:09 PM
machinegunsquid Re: headlights bounce around 02-19-2011, 11:10 PM
NewBoost1997 Re: headlights bounce around 09-21-2011, 10:28 AM
tcman49 Re: headlights bounce around 09-21-2011, 11:20 AM
machinegunsquid Re: headlights bounce around 09-21-2011, 02:15 PM
Juanmiguel Re: headlights bounce around 09-21-2011, 04:51 PM
Ricky21 Re: headlights bounce around 09-21-2011, 05:18 PM
Below Average Joe Re: headlights bounce around 09-22-2011, 11:43 AM
machinegunsquid Re: headlights bounce around 09-22-2011, 12:53 PM
andremike Re: headlights bounce around 11-09-2011, 12:42 PM
Pepino Re: headlights bounce around 11-11-2011, 06:29 PM
twol8uluz Re: headlights bounce around 11-09-2011, 01:30 PM
PurpleGuy Re: headlights bounce around 11-09-2011, 02:17 PM
machinegunsquid Re: headlights bounce around 11-09-2011, 09:37 PM
smitz327 Re: headlights bounce around 02-08-2013, 02:31 PM
andremike Re: headlights bounce around 02-09-2013, 11:27 AM
  1. #1 headlights bounce around
    GT Level Member fremmy182's Avatar
    Center Moriches, New York
    i was wondering if any of you guys use something to make them stop doing that, i feel like the projectors are ganna break. i used Styrofoam but its ugly
  2. #2 Re: headlights bounce around
    Florida
    Use some foam, with tape on the other side. Sell it at lowes/home depot..hold them in place great.
    Or some thick weather stripping.
  3. #3 Re: headlights bounce around
    where can i get thick weather stripping from.. autozone?
  4. #4 Re: headlights bounce around
    Never Never Land
    stripping of a trunk deck is what i used
  5. #5 Re: headlights bounce around
    Florida
    Lowes/home depot. Maybe even wally-world.
    Mine, I used some thick weather stripping around the fender/where the turn signal is, and some of the foam under the headlight. Looks really good too.
    Cost about 5-10bucks at a home supply store.
  6. #6 Re: headlights bounce around
    thanks guys, pontiac really should of done a better job with the headlight bolts lol
  7. #7 Re: headlights bounce around
    Florida
    Meh...works fine with stock headlights....just not aftermarket...
    atleast its a cheap/easy fix...just a PITA.
  8. #8 Re: headlights bounce around
    SE Level Member NewBoost1997's Avatar
    Jul 2010
    Minnesota
    can someone put a picture up of what they did? I'm having the same issue..
  9. #9 Re: headlights bounce around
    GT Level Member tcman49's Avatar
    Apr 2011
    Palm Coast, Florida
    Yeah, friggin headlight mounts are a joke, I bought after market, though matching stock headlights units and to readjust the things like three times before they would stop bouncing.
  10. #10 Re: headlights bounce around
    Florida
    NewBoost, if you look in my sig picture, I just put some of the prior mentioned foam around the chrome part of the headlight, and ta-dah! no bounce.
  11. #11 Re: headlights bounce around
    GTX Level Member Juanmiguel's Avatar
    Mexico
    I used some of that seal foam strip thing that they sell at the home depot that comes in a roll. They sell it in the A/C stuff section to seal doors and s h i t.
  12. #12 Re: headlights bounce around
    Minnesota
    The weatherstripping foam works well just like everyone said. I have also seen some people use the stock healight brackets on projectors and that seemed to works well. That or make up a set of retro fits, that seems to be the best headlight set up for our cars
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  13. #13 Re: headlights bounce around
    Aug 2011
    'Merica
    Quote Originally Posted by Ricky21 View Post
    What does retro fit mean? I have seen this term on here frequently.
  14. #14 Re: headlights bounce around
    Florida
    You take a real, legit projector, and do some sort of voodoo to get it inside the factory Grand Prix headlight, thus retrofitting it with a HID projector.
  15. #15 Re: headlights bounce around
    GT Level Member andremike's Avatar
    Nov 2009
    chicago
    I just bought stock replacement headlights from amazon and I notice some bounce to the headlights... Should I add the foam around the headlights? Does the ofam go on the bottom or the top? or all the way around? I didn't buy projectors because I thought they would bounce and here I buy the chinese made aftermarkets and they bounce.. Do you think its the brackets? Should I try swapping the mounting brackets?
  16. #16 Re: headlights bounce around
    Brewcity, WI
    Quote Originally Posted by andremike View Post
    idk, but I'm trying it with mine and will let you know
    Self-denied SMGPFC member #1
    SEARCH works!
  17. #17 Re: headlights bounce around
    michigan
    I've used the adhesive foam strips I've found at autozone. I cut off maybe a 6" strip and stuck it on the underside of the headlight. Tuck it far enough back so its not so visible, but its black so its not too much of an eyesore if seen. Its def helped my bouncy light situation, hope it helps yours.
  18. #18 Re: headlights bounce around
    Never Never Land
    How well do you think a set of factory brackets would help with bounce? I have new OE style lights and they bounce like hell.
  19. #19 Re: headlights bounce around
    Florida
    Mebbe a little bit. Just be careful swapping them, as to not break anything.
  20. #20 Re: headlights bounce around
    Donating Users smitz327's Avatar
    Oct 2012
    Illinois
    Just finally fixed mine by looking at another thread. The best solution I have found is get some Styrofoam about say 2 inches thick and about 4 to 6 inches long and stick the piece between the metal on the bumper and the bumper cover just below the headlights. You may need to slightly bend the mounting on the frame of the car where the lights attach to but that will definitely fix any problem with bouncing. You can even use a piece of wood to do it also like say a 2 by 4 but I wouldn't recommend that because of it getting wet
  1. 2004+ Headlight Bounce Kit?
    By UCF04GPGTPCompG in forum Visual/Body Modifications
    Last Post: 06-29-2013, 10:30 PM
  2. OEM style headlight bounce
    By BoostnBlackGTP in forum Visual/Body Modifications
    Last Post: 01-02-2011, 12:31 PM
  3. Head light bounce
    By stlunatics2oo3 in forum Visual/Body Modifications
    Last Post: 12-13-2010, 03:12 PM
  4. Valve Float and Bounce
    By SyntheticShield in forum General Tech Discussion
    Last Post: 12-19-2008, 04:02 PM
