Thread: difficulty of install: cat and O2 sensor on 01 GT
Results 1 to 5 of 5
Threaded View
  1. #3 Re: difficulty of install: cat and O2 sensor on 01 GT
    Apr 2009
    stockton ca
    Its straight forward spray the bolts with penetrating oil first(liquid wrench,pb blaster,wd40) let sit an hour or so and it really helps if you have access to air tools but if not more then likely you will need a breakerbar for the exhaust bolts
    The o2sensor is easy as well just depends wich one you want to change out
    A o2 sensor socket is handy autozone rents the o2 sensor kit
  1. No o2 sensor ??
    By Bigbm80 in forum General Tech Discussion
    Last Post: 07-07-2009, 05:55 PM
  2. '92 GTP M-284 ECT/CTS sensor
    By kmckirryher in forum 3.4L V6 (LQ1) DOHC
    Last Post: 11-15-2008, 10:03 AM
  3. bad sensor maybe
    By Charged97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2008, 12:28 AM
  4. Difficulty on Ebrake Cable
    By gtman98 in forum General Tech Discussion
    Last Post: 08-31-2008, 10:47 PM
  5. dash gauges...difficulty and opinions?
    By fst in forum Visual/Body Modifications
    Last Post: 05-20-2008, 08:44 AM
