Thread: vacuum lines
Results 1 to 8 of 8
  1. #1 vacuum lines
    GT Level Member shawn3091's Avatar
    Jan 2009
    State College PA
    i need the 90 degree rubber ends, mine are split and cracked, where could i get them or does anyone here have good ones that i could buy? I dont really want to put rubber hose on to replace them
  2. #2 Re: vacuum lines
    GT Level Member hourang's Avatar
    commerce, mi
    i would just replace with the same size cut to length vacuum hose from the auto parts store.
    -Jeff
    98 GTP Black 4dr - fully loaded - short ram intake, tinted tails, hole in resonator.
    sold 98 camaro ss - 6spd fully loaded - cam, intake, exhaust, ford 9in rear 4.11s, 6point chromoly cage, tnt 150shot nitrous, nittos, etc.
  3. #3 Re: vacuum lines
    Apr 2009
    stockton ca
    maybe try gm i tried napa,kregan,pepbys,autozone,carquest with no luck my vac lines are all rigged up right now
  4. #4 Re: vacuum lines
    Jan 2009
    State College PA
    guess im going to use vacuum hose
  5. #5 Re: vacuum lines
    Charles City, IA
    You can get a whole vacuum line kit from gm.
    SMGPFC Two Nipple General
  6. #6 Re: vacuum lines
    Jan 2009
    State College PA
    i finally found ends, dorman #47408
  7. #7 Re: vacuum lines
    Apr 2009
    stockton ca
    Ill be getting a whole kit from gm or getting better silicone hose and fitings
  8. #8 Re: vacuum lines
    commerce, mi
    plastic hoses suck
    -Jeff
  1. 2000 grand prix GTP vacuum lines
    By MikeGabyrs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-17-2011, 11:34 PM
  2. Different Vacuum Lines...
    By Iron Indian in forum General Tech Discussion
    Last Post: 08-17-2009, 12:47 AM
  3. Identify vacuum lines etc...
    By nmgadb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2008, 12:52 PM
  4. SS fuel Lines
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-15-2008, 01:02 AM
